KZ750G (twin) blinkiing brake indicator light
  • oldryder
  • oldryder's Avatar Topic Author
09 Jul 2014 08:48
#639421
Presently resurrecting a 1980 Kz750G.
Good progress electrically but when key is on the brake light dash light blinks continuously. brake light bulb is fine.
Suggestions anyone.
  • bountyhunter
  • bountyhunter's Avatar
Re: KZ750G (twin) blinkiing brake indicator light
09 Jul 2014 11:56
#639442
some possibilities:
the brake light sensor unit is bad
the brake light bulb is LED type so the impedance is too high and the sensor sees it as an open filament.
open circuit in connector or wire to the bulb
  • pete greek1
  • pete greek1's Avatar
09 Jul 2014 12:13
#639447
Some more possibilities
corrosion in the tail light socket & or bulb
corrosion in the wire fittings from front brake master to front brake sensor
bulb might look O K but could be bad
corrosion in tail light wire connectors to harness
Pete
09 Jul 2014 19:04
#639500
oldryder wrote: Presently resurrecting a 1980 Kz750G.
Suggestions anyone.
Does the brake light work while the dash light is blinking?
The blinking dash light is supposed to be warning that the brake light is inoperable (for whatever reason).
Good Fortune! :)
