aftermarket tach on my 82 1000 ltd
- Beaner242
27 Jun 2014 14:08
The bike came with an electric tach. Im not using the factory gauges so im looking for a replacement. I found this one on ebay but its talking about dual fire ignition and I have no idea what I have? will this one work?
mini tach
mini tach
1982 KZ1000K LTD Chopper
Re: aftermarket tach on my 82 1000 ltd
27 Jun 2014 14:32
By "dual fire" I they probably are referring to a wasted spark ignition system. This is the type in which each coil fires 2 spark plugs simultaneously even though only 1 of the 2 cylinders is on the compression stroke. This is how the 4 cylinder Kawasaki KZ's work. Check with the seller to ensure that is what he means. Ed
- Beaner242
27 Jun 2014 14:55
Thanks ED. I knew I could count on you. LOL
