Speedo needle?
  • yeekim
  • yeekim's Avatar Topic Author
Speedo needle?
27 Jun 2014 05:51 - 27 Jun 2014 14:09
#638132
Hi!
Have an issue with KZ750 P1 shaft speedo needle.
The trip meter and odometer are working correctly but the needle shows a little bit less than normal.
Cable and the drive are OK.
Can enyone point to the solution in this forum or ...
Hammer :whistle:
Ex nihilo nihil fit!
Last edit: 27 Jun 2014 14:09 by yeekim.
  • bountyhunter
  • bountyhunter's Avatar
Re: Speedo needle?
27 Jun 2014 12:14
#638155
correct front tire size?
  • yeekim
Re: Speedo needle?
27 Jun 2014 14:08 - 27 Jun 2014 14:11
#638161
As I told, the trip and odo are showing correct value- made a 1 km run.
Front tyre is as on factory...
Last edit: 27 Jun 2014 14:11 by yeekim.
  • pete greek1
  • pete greek1's Avatar
Re: Speedo needle?
27 Jun 2014 15:50
#638171
It don't count if you're doing a wheelie :woohoo: :woohoo:
