82 KZ1000-K2 Turn Signal Issue
  • nicksorg
  • nicksorg's Avatar Topic Author
27 Jun 2014 03:26
#638117
Hey all. Just picked this bike up last weekend. Last issue is turn signals. left turn signal works fine front and back. Right side isn't working, though right front running light is on. Is there a separate flasher for right side? Can someone provide a wiring diagram?
Thanks
Nick
1982 Kawasaki KZ1000-K2
Re: 82 KZ1000-K2 Turn Signal Issue
27 Jun 2014 04:40 - 27 Jun 2014 04:41
#638124
Last edit: 27 Jun 2014 04:41 by Patton.
The following user(s) said Thank You: KZTRIP
27 Jun 2014 04:45
#638125
There is one flasher unit that controls both sides. Check the right side front/rear bulbs and the wiring - it could be a disconnected wire, bad connector, or possibly a bad ground on the rear signal. If the bulbs are good (you can swap in the ones from the left side to check) I would start tracing the wiring from the turn signal stalks. Ed
  • nicksorg
27 Jun 2014 05:39
#638130
Thanks for the diagram. Bulbs are good front and back. The rear bulbs are dual-filament, but I believe should be single. As mentioned earlier, the left side works OK.
Thanks
Nick
  • Motor Head
  • Motor Head's Avatar
27 Jun 2014 06:08
#638134
nicksorg wrote: Thanks for the diagram. Bulbs are good front and back. The rear bulbs are dual-filament, but I believe should be single. As mentioned earlier, the left side works OK.
Thanks
Nick
I believe you'll find that the front signals should be dual element and the rear single. In the front, you should have running/ marker amber lights on with the headlight. Then turn signals. In the rear they're just turn signals. Look inside at the bulb socket, you can see if it is a single or dual bulb connection by the center of the socket where the bulb touches.
  • nicksorg
27 Jun 2014 06:47
#638136
Correct. The front are marker and turn signals with dual element bulbs. The rear are turn signals only. Knowing that there is only one flasher, I need to do some more troubleshooting.
Thanks
  • MFolks
  • MFolks's Avatar
27 Jun 2014 09:55
#638150
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb(s)
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
  • nicksorg
28 Jun 2014 14:11
#638298
All fixed. It was a number of things:
After-market bullet signals in the front were not wired correctly. I also removed the stock rear turn signals and cleaned the internal connections and mating surfaces. All signals now function correctly. Thanks for all the input.
Nick
The following user(s) said Thank You: MFolks
