Z1-R Front Brake & Clutch Cutout Switches
- weales
26 Jun 2014 05:04
Both these switches on my'78 Z1-R are shot- has anyone located a source for these obsolete/deleted items, or maybe have some for sale?
Current Project
1968 Norton P11A Desert Sled
Other bike (and daily ride)
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
Re: Z1-R Front Brake & Clutch Cutout Switches
26 Jun 2014 05:30 - 26 Jun 2014 05:32
Take a look at the diagram below. If the parts you need are marked #11 and #18 here's some info. The part marked #11 is obsolete, but can be found on eBay. Here's a link for some examples of new old stock ones -
www.ebay.com/dsc/i.html?_sop=10&_from=R4...at=0&_odkw=27043-002
According to Kawasaki.com the part marked #18 is still an "ACTIVE" Kawasaki part, so any dealer can order it. Partzilla lists it at $13.27 - here's the link -
www.partzilla.com/search/?q=27021-004&x=9&y=6
Attachment 00003_2014-06-26.jpg not found
Last edit: 26 Jun 2014 05:32 by 650ed.
26 Jun 2014 05:46
i had to purchase number 18 in ed's diagram a couple years ago.
it is also shared with many kawasaki models
i remember thinking that it looked just the same as the one for the clutch.
can't completely confirm it will work for you but i bet it will.
if i can remember to check this evening i will.
i have a clutch and brake perch complete used items hanging on the wall.
26 Jun 2014 05:51 - 26 Jun 2014 05:56
According to Kawasaki.com the Z1-R and KZ650-C1 take the same clutch / starter lockout switch. Here's some info I provided another member that may be helpful (see link below). You may want to pull the switches from the perches (very easy to do) to check to see if Leon is correct about them being the same. It could be that just the length of the wires are different which may not be a problem. Ed
www.kzrider.com/forum/4-electrical/594587-electric-start#637726
Last edit: 26 Jun 2014 05:56 by 650ed.
- matteodoors
29 Jun 2014 18:50
hello guyz
I am looking to upgrade my front and rear turn signals for my 75 z1 900 B. Does anyhow have any ideas or pics they can reply with, as i would like to give mine a bit of a face lift. Thanks.
- weales
29 Jul 2014 20:03
'78 Z1-R Front Brake and clutch switches are not interchangeable - the clutch one has a larger diameter barrel than the brake one! Managed to refurbish the clutch cutout switch - some WD-40 to clean and lube it and a bit of TLC on the harness/connectors. I got a front brake switch from 2wheelpros for $16-00 ($28-00 postage though!) Working on a circuit to disable engine if gear is selected with sidestand down - most modern bikes have this as standard fitment. Will post something in the electrical section when it progresses.
Current Project
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
