KZ 1000 1981 Need plug wires
- lucienmaier
19 Jun 2014 15:24
Anyone know where I can snag
a set of Orange Spark Plug wires for my 1981 KZ1000m csr....
Attachment 2014-06-091.jpg not found
--1981 Kz1000m CSR--
--Converted to 1100CC---
- 9er rider
- Keep a cool tool
Re: KZ 1000 1981 Need plug wires
19 Jun 2014 15:56
I usually go to the local speed sh0p and hope honey bunny really seems to be on it with understanding of the timely series priority list. and promise you'll drink lots of water and walk real slow :pinch:
- MFolks
19 Jun 2014 18:22
7mm copper sparkplug wires will fit, avoid the carbon fiber(suppression) ones, as they will not last long.
Ignition Coils And Sparkplug Wire Choices
What came with the bike, were ignition coils that even when new were marginal, add years of cooking under the tank in the stop and go traffic, and the ignition coils will probably fail when hot.
Replacement coils can be bought at www.z1enterprises.com
I believe “Emgo” is the brand. They also carry the popular Dyna 2.2 and 3 ohm coils, along with replacement sparkplug wires.
Now, you have a choice on sparkplug wires:
1. Copper plug wires with no supression caps (the best choice, but will produce audio noise on Radio’s and TV’s). Not only do the copper core wires deliver better spark, they will also deliver a much longer lifespan - carbon core wires are prone to erratic spark delivery and early breakdown, & short lifespan.
2. Copper plug wires with supression caps (a built in 5000 ohm resistor, that can sometimes fail, like what came with the bike). These should be checked with a multimeter now and then, as heat can cause them to become intermittent.
3. Copper plug wires with no supression caps, but using resistor plugs(the “R” in the plug number).
4. Supression plug wires with no supression caps.
NEVER use resistor plugs combined with supression caps along with supression plug wires, as now there will be possibly three (3) sources of resistance in the secondary windings of the ignition coils, greatly reducing the spark energy.
Another choice is the Accel 3 ohm coils, with a similar, primary(small wire)electrical connection, using ring terminals as the Dyna ignition coils do. Whatever brand of coil you go with, make sure the primary wires will clear the mounting hardware, as the spacers come close, possibly blowing a fuse. Some riders have replaced the metal spacers with non conductive Nylon spacers, reducing the chance of an electrical problem.
7mm sparkplug wires will fit the stock ignition coils(if they have replaceable wires, indicated by screw off caps on the coils with ridges). The sparkplug wires fit into a port with a brass ”Stinger” that goes into the sparkplug wire or lead(the Brit’s. Canadians, and other countries call the sparkplug wires (“High Tension Leads”).
