kz1000 Stator help. Frustrated.
- mayday119
17 Jun 2014 17:46
Hey guys, Quick back story. The bike is a kz1000. the title reads '82 but i know its a hybrid build and hard to identify the exact year of alot of the parts. Im in the process of an overhaul. I have been chasing an electrical problem for the better part of a month now. I have replaced the coils, plugs , wires as well as the regulator. Now whats left is the stator. Everything else is new. Theres no ground problems, there are no shorts or wrong connections. Iv ordered a stator twice now, Based on 2 different models. One was an '82 based upon the title I figured it was. But why would it be that easy right? Turns out it was the wrong one, To large. So i called the original owner, Turns out he said the motor was a kz1000 1978-79 mark II LTD ? So i ordered the stator from that motor, it was even Bigger then the one previous. So im lost and holding for help. Heres pictures for reference, Help me identify the motor or even better, point me in the right direction for the stator i require. Im getting a bit frustrated because im missing great riding weather.... thank you in advance,
Heres the only identifying marks on the block I could find
heres the New starter next to the old one ( new on right old on left)
Measurements. New then old. the Old one is notably smaller and the bolt pattern isnt the same.
heres the box with part numbers
- bluezbike
Re: kz1000 Stator help. Frustrated.
17 Jun 2014 17:51
Best way is to first find out exactly what motor you do have.......there should be a serial number stamped right next to the oil filler port......then go to
www.zedder.com
and look up what you got :)
79 KZ 1000 LTD
- wireman
17 Jun 2014 19:30
Does the stator cover say dohc or Kawasaki on the outide?
If it has Kawasaki cast into the outside id look for a 79-80 mkII or ltd stator,if it says dohc you need the older style stator which should be the larger of the 2 .
- etbike3135
18 Jun 2014 04:04
The motor does appear to be "KZ" and not "J". KZ motors has a kick start and J motors did not. J Motors were 81 and above. That stator was only on 79/80 KZ motors and was always the smaller size. There are only 2 sizes so if you found 3 sizes then the place you bought the stator from screwed up.
1973 Kawasaki Z1
18 years in dragbikes
- MFolks
18 Jun 2014 09:41
I'd return the stator, and notify the supplier of the mismatch problem.
Some other Motorcycle electrical parts suppliers:
Stators, Regulators & Rectifiers
www.rmstator.com
store.prestoliteperformance.com/accel-mc...z1000-1100-1300.html
www.electrosport.com
Kawasaki 77/78 1000A. www.denniskirk.com/jsp/product_catalog/P...tId=&mmyId=10274
Kawasaki 79 1000ST.
www.denniskirk.com/jsp/product_catalog/P...atId=&mmyId=1656
www.customrewind.com
www.oregonmotorcycleparts.com/ (not sure if they have stators)
www.regulatorrectifier.com
www.accel-motorcycle.com/
www.tpe-usa.com/ (Tim Parrott Enterprises)
www.rmstator.com
Kawasaki 79 1000ST.
- mayday119
20 Jun 2014 23:06
You guys were a great help. Problem resolved. New stator installed, now time to tune carbs and address the flooding issue
