New battery arcing
- 4TheKZ1000
Last edit: 11 Jun 2014 18:37 by 4TheKZ1000.
- Motor Head
Re: New battery arcing
11 Jun 2014 19:06Lapp3591 wrote: Ok so here's the update as of now. There are two wires going from the negative post. One gives power to all the electronics and they all work as they should. The other just makes it spark like crazy and one wire started to smoke. The starter clicks so now I'm assuming the relay might be bad? The wire that smokes looks like it may have been tampered with before...I'm at a total loss
Please put your wire Colors into your post.
The Black and Yellow stripe wire are the ground, which go to the negative post. The Red and white striped wire goes to the positive post.
Use your meter to verify that the battery is charged correctly, while rare they can be reversed charged, so the current is back wards. Then the Positive marked post will be negative and the negative positive. It only takes a dead battery and to hook the charger up backwards.
11 Jun 2014 23:38
The 1980 KZ750 LTD at hand could be a twin KZ750-G1 (LTD II), or it might be a 4 cyl KZ750-H1 (LTD).
- Lapp3591
12 Jun 2014 09:17
I'm posting a few pics to maybe help my cause. The bike is a 4 cylinder if that helps too.
