relay/fuse question
- worior1
relay/fuse question
05 Jun 2014 15:39
So i want to upgrade my relay and fuse box on my 83 kz650 to something newer and more reliable
Does anyone know of any good aftermarket solutions of this? Everything i look at is made for big twin motors cant find anything for a small 4 so any input is great
Thanks
Thanks
Re: relay/fuse question
05 Jun 2014 15:45
Which relay? Ed
- worior1
05 Jun 2014 16:01
All of them, the whole area around te battery is hanging on prayer fairly much and while rebuilding the bike i would like to retrofit it
05 Jun 2014 16:27
For the turn signal relay you can use a Tridon/Stant 552 2 prong. It is a direct replacement (same size & shape as original) but it is electronic so it flashes much more consistently that the original. I found the original unit flashed at different speeds depending on the state of charge of the battery and the engine rpm. It MIGHT also work for the hazard flashers, but you would need to test it to confirm. Ed
05 Jun 2014 18:34 - 05 Jun 2014 18:34
Last edit: 05 Jun 2014 18:34 by martin_csr.
- worior1
06 Jun 2014 02:42martin_csr wrote: Fuse box upgrade. I guess it's a direct fit?
cwswiring.com --- Creative Wiring Solutions --- FH-01
i was looking at those the other day however i dont think it fits the CSR models as he doesnt have them listed in his compatability chart
06 Jun 2014 03:46
It has 3 fuses & appears to be the same size, so it will probably work.
It may not be a direct plug-n-play, so you'll probably just have to do some simple wiring connections.
The following user(s) said Thank You: worior1
- worior1
06 Jun 2014 05:45
well i dont need it to be a direct fit as far as size is conserned, its all going to be tucked away into an electronics box anyways
- Beaner242
06 Jun 2014 06:32
Autozone carries a few fuse panels you may be able to fit one.
1982 KZ1000K LTD Chopper
- worior1
10 Jun 2014 06:05
i found a 4 fuse panel on ebay that i think might work with a little rewiring, i plan on making a new mouting bracket for all these components as well, prolly gona use 3 inch pipe and just end cap it making it look like an oil tank por something to hide all the electronics in, just gota do some more reasearch to make sure that nothing in there needs to be air cooled so i dont have any insidents lol.
- saxjonz
- KawboyZ
10 Jun 2014 14:59
I wanted to buy one of these the other day...out of stock.
worior1 wrote:martin_csr wrote: Fuse box upgrade. I guess it's a direct fit?
79 LTD B3
