how long to charge battery?
- steveo_4192003
- 77kz650b-1
04 Jul 2006 23:27
ok,i got bike going and running great!
the battery (new)but has been running has 10 volts with lights on, and 11.4 or so off!
i rode around the (city) block and didnt see a change.
how long will i have to ride to charge back to 12+
just wanted to know if my charging-system is working!
how long can i ride just off the battery?
it died at a gas station and it wouldnt start after a hour or so of riding!!
thanks
Post edited by: steveo_4192003, at: 2006/07/05 02:28
thanks
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
- btchalice
Re: how long to charge battery?
04 Jul 2006 23:33
an hour of straight riding should have done it :blush:
have you checked voltage output with a meter? should be between 13.5 and 15.5 at 2k rpm
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- steveo_4192003
- 77kz650b-1
04 Jul 2006 23:52
sorry, i put down i rode around for a hour. this is not right.
i rode around the block 1 time to see if i could see a differance! and didnt see any.
im going to go for a longer trip next time!
how long should it take? 15 min or so?
just want to know how long to ride for it to get back at 12+ volts?
- wiredgeorge
05 Jul 2006 06:51
It will take it longer than a ride around the block. The ride around the block was problem done at speeds just under idle. At idle, your regulator will cause about 12.5 VDC to hit the battery which isn't really going to charge it. You need about 14VDC to get that battery recharged and this comes at 4K rpm or so... get out on the highway and ride it some at speed. The longer you ride, the more it will charge so if you ride 3 miles at 60 mph and come home, it will charge a little bit but not much... ride 30 miles and you will likely have a pretty full charge if it is discharged. You could also go to the autoparts store and get a "trickle charger" - these put out only about 1/2 AMP and are little small chargers meant for a motorcycle. Mine is about 6" long and about 3 inches high. I think they should cost about $25-30. The only setting will be 6 or 12 Volts... keep it on 12V and charge overnight... A car charger will fry your battery. Get one with less than an amp of current for charging. Make sure the battery acid is up to the line indicated on the battery. If it is low, use DISTILLED water as tap water will ruin your battery in no time. It has minerals that stick to the plates... then they short.
- steveo_4192003
- 77kz650b-1
05 Jul 2006 09:38
ok , went out today and rode for about 2o min, then it started acting like its to rich or lean!
rode back up my rode and it sputterd like it had no power, measured the volts on batery and only have 8 volts now, started with 12!
what to check first??
- steell
05 Jul 2006 09:49
In the Filebase (Listed under "KZ Information" at the top of the page).
Electrosport Fault Finding Flow Chart
And:
ELECTRICAL fault_finding
And:
- btchalice
05 Jul 2006 09:52
start with cleaning all connectora and grounds any of them can prevent charging
- trippivot
06 Jul 2006 05:23
Amperage charges batteries Amperage not Voltage. everyone remember if you are not checking for charging current(amps)at the battery, the voltage reading will be a FALSE indicator of your charging system and regulator condition.
Motorcycle charging systems are not designed to charge your battery. It is designed to only cover the electrical loads while running.
maitnence charging is required.
charging rate for a 14 - 16 amp hour battery is safe at 2 amp charge 6-8 hours.
higher settings 6 or 10 amps must be monitored for the prevention of heat or boil over. these batteries are delicate compared to bigger automobile batteries.
they warp plates really easy and you wont notice except the thing goes weak.
- loudhvx
06 Jul 2006 09:49
But voltage forces current. If the battery is not damaged, sufficient voltage applied to it produces the current to recharge the battery. A battery charger charges the battery the same way the bike does. It applies a voltage to the terminals higher than the ambient voltage of the battery. This forces current through the battery, recharging it.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
