Spark plugs
  • eric77kz
  • eric77kz's Avatar Topic Author
Spark plugs
21 May 2014 07:01
#633239
While replacing my plugs, plug wire #4 broke off! No pic to show but the end where it was in the wire has a screw in it and dont know what to do to replace/fix!
77 KZ650 C
Re: Spark plugs
21 May 2014 07:27
#633245
Are you saying the cap that attaches to the plug simply came off the wire, or did the cap itself actually break? If it just came off the wire you can just screw it back into the wire. If it actually broke you'll need a replacement. Ed
  • eric77kz
Re: Spark plugs
21 May 2014 07:31
#633248
It did not break. There is a screw sticking out inside of the cap but I dont see a place to screw it back in the wire.
77 KZ650 C
  • Cynjut
  • Cynjut's Avatar
Re: Spark plugs
21 May 2014 07:33
#633249
eric77kz wrote: It did not break. There is a screw sticking out inside of the cap but I dont see a place to screw it back in the wire.
It just screws into the end of the wire. The screw attaches to the wire in the center of the wire and secures itself to the insulation at the same time.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • ZERO
  • ZERO's Avatar
Re: Spark plugs
22 May 2014 03:37
#633404
Take some cutters and snip off about 1/4" of the old coil wire off, then press the cap onto the wire and spin in clockwise until it's tight. You're done. The "screw" digs into the core metal of the wire and creates a good contact.
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
The following user(s) said Thank You: eric77kz
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Spark plugs
22 May 2014 03:43
#633406
A pair of dyna coils and new wires is a nice upgrade if theres money in the budget.
  • eric77kz
Re: Spark plugs
22 May 2014 08:45
#633430
No Budget money yet but soon very soon. The old wire is so short there was no room to snip. But I did get it back on there!
77 KZ650 C
