KZ1100 Spectre non-working Tach
- KZQ
- Administrator
19 May 2014 21:17
The tach on my 82 Spectre hasn't worked since I've owned it. I purchased another working tach from a member here but it won't work on my Spectre. Where is it that the tach get's it's signal?
Any help will be appreciated.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- MFolks
Re: KZ1100 Spectre non-working Tach
20 May 2014 15:35
If you bike has a button on the instrument panel, that makes the Tach act like a Voltmeter(some bikes did), see if the wiring goes to one of the ignition coils, as this is usually where the Tach got the signal to trigger it. Maybe Green or Black wires.
- loudhvx
20 May 2014 22:17
Signal is from the black wire on the coil for cylinders 1 and 4..
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- KZQ
- Administrator
21 May 2014 15:09
Thanks Guys.
With two tachs refusing to work I'm going to pull the tank and go looking for a bad connection or a broken wire between the 1/4 coil and the tach.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- loudhvx
21 May 2014 23:00
You can just ohm out from coil to the tach. But unplug the big wires from the igniter so it's not in the circuit.
1981 KZ550 D1 gpz.
Other links.
Other links.
