what stator wire goes where?
  • lawcampbell
  • lawcampbell's Avatar Topic Author
18 May 2014 15:07
#632864
Hey folks. Replace d stator cover gasket on 93 kz 1000 and the stator wires came unplugged. Three black wires coming from stator housing and three yellow wires coming down from upper cover. How do I tell which one connectes to another ? Does it matter? Thanks
  • zed1015
  • zed1015's Avatar
Re: what stator wire goes where?
18 May 2014 15:27
#632866
Doesn't matter which way they go.
  • MFolks
  • MFolks's Avatar
18 May 2014 16:00
#632870
The stator is wired 120 degrees apart, so as long as there is no electrical short to ground, it doesn't matter about which goes where.
Alternator Testing For the Older 4’s(Z1’s,Kz 900’s, Kz1000’s,Kz1100’s and GPz1100’s).
To check to see if the alternator is working you need to follow these simple steps:
1. Fully charge the battery as this will be the power source during this test.
2. Disconnect the Regulator/Rectifier at the plug that has the six wires in it.
3. Start the engine and let it warm to operating temperature.
4. If you're worried about overheating, position a large fan for cooling the engine.
5. After the engine has reached operating temperature, have a helper assist you, and using a multi-meter, read the output at the three yellow wires (or the alternator output wires)at the disconnected connector.
6. Raise the engine speed to 4000 rpm, and see what the three YELLOW wire combinations(or any alternator output wires) are(1-3, 2-3 & 1-2). The output will be around 50 Volts A.C.(Alternating Current). BE CAREFUL, AS THERE IS A SHOCK HAZARD HERE!!
7. If any of the combinations are low or non-existent, the stator(wire windings) are bad and must be replaced.
Some of the older Z1’s and KZ900’s were reported to be phase sensitive, so check the wire colors carefully.
8. Using an OHMETER, Check the three wire combinations again, looking for a reading of 0.36 - 0.54 OHMS. If the readings are above or below, the stator may be bad and need replacement. Also check from any of the three YELLOW wires to ground, this will show if arcing took place. Check only with the engine off !!
9. Before ordering a new stator, check the connections from the stator as there are electrical "Bullet" connectors that may be damaged or dirty.
Inspect the wiring for signs of shorting or overheating too. www.z1enterprises.com sells replacement rubber grommets for the alternator output wiring, they get hard and could leak oil after a while.
10. Check the wiring coming out of the grommet as there have been situations where the wires were damaged causing a short(I.E. twisted together with insulation damage).
11. The sprocket cover will have to be removed to access the electrical connectors coming from the alternator, the left foot peg assembly and shifting lever will have to come off also.
  • lawcampbell
18 May 2014 23:06
#632903
Right on, thats what I need to know
..(more newbe questions to come)
