Eliminated turn signals.
- Medicontheloose
18 May 2014 10:23
Quick question for the masses. I've eliminated my front signals on my 80 KZ750E cafe project. Is there any need to do anything other than cover the ends of the open wires?
Thanks in advance.
Thanks in advance.
"That others may live."
1980 KZ750E
1980 KZ750E
- MFolks
Re: Eliminated turn signals.
18 May 2014 11:28
I'd suggest getting an electronic flasher relay to replace the stock silver can ones, as the electronic one should compensate for only two turn signal bulb filaments, instead of the 4 you once had. Make sure the electrical "Pins" fit the connector(bring your old one along to compare), as most auto parts stores carry the electronic flasher. To keep corrosion away from the open connectors, get some low temp heatshrink, cut it about 1/2" long, fit it half way down the connector, heat up the tubing, and while still hot, pinch the open end with a pair of pliers. This should seal up the end.
- kaw-a-holic
18 May 2014 17:33MFolks wrote: I'd suggest getting an electronic flasher relay to replace the stock silver can ones, as the electronic one should compensate for only two turn signal bulb filaments, instead of the 4 you once had. Make sure the electrical "Pins" fit the connector(bring your old one along to compare), as most auto parts stores carry the electronic flasher. To keep corrosion away from the open connectors, get some low temp heatshrink, cut it about 1/2" long, fit it half way down the connector, heat up the tubing, and while still hot, pinch the open end with a pair of pliers. This should seal up the end.
The LED flasher can be purchased @ Napa. If you want emergency flashers to work I believe you have to replace both flasher units with LED flashers.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- fastidiots
18 May 2014 21:40
found this company a while ago... haven't bought from them but planning to get their flasher unit soon.
Bonus that its specifically designed to fit Kawi's!
www.cwswiring.com/Shop.html
82 KZ1000 J
76 KZ750 B1
76 KZ750 B1
- Medicontheloose
23 May 2014 15:20
Awesome. Thanks all for the info.
1980 KZ750E
1980 KZ750E
