dyna shift minder
- toad
dyna shift minder
13 May 2014 15:30
has anyone hooked up a dyna shift minder DSM-4H, I have power to the light but cannot get it to flash at the desired rpm setting.I ran the green wire to the positive side of each coil, black to ground and red to 12v switched.Wondering if I have the green wire correct..
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- toad
Re: dyna shift minder
14 May 2014 15:16
anyone run one of these?
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- loudhvx
14 May 2014 22:04
How does it sense the RPM? The positive side of the coils is always near 12v.
I think you want to connect the green wire to the negative side of the coils.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- zukdave
18 May 2014 09:45
You wire it just like an elect. tach.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
