Ignition System
  • Tommyhash82
  • Tommyhash82's Avatar Topic Author
Ignition System
05 May 2014 09:18
#631383
Ive got a 1978 KZ100 my dad left me when he passed away. Ive stripped it down and repainted it all and started putting it all back together. ive got a new set of accel coils and I on it and I don't know witch wire goes were on the coiles the wires were all unhooked when I stared. Does anyone know what wire goes where?
  • Cynjut
  • Cynjut's Avatar
Re: Ignition System
05 May 2014 09:47
#631388
The coil wires go to cylinders 1 & 4 on one coil and 2 & 3 on the other coil. The green wire looks like it feeds the coil to 1 & 4, but the diagram I have isn't too clear on which spark plugs are which. The brown wire should feed the other coil. The red-yellow wires should go to both. While there doesn't appear to be any specific connections, try to hook them up the same (R-Y wire to the bottom or top on both) if only because the ADD afflicted amongst us will be bothered if you don't. :-)
Chilton and Clymer both make good books for this bike, and both have detailed, by-year, wiring diagrams.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
