Starter Motor Help
- Topper
Re: Starter Motor Help
21 May 2014 03:32
I usually have to wedge a large screwdriver in between the starter and case, then tap the screwdriver with a rubber mallet.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- hightower666
21 May 2014 04:49
Thanks, I've tried with the biggest screwdriver I have, but will persist. As long as I'm not missing something like another hidden screw.
- hightower666
22 May 2014 09:19
Ok, I've got it out thanks. It was really stuck tight, loads of crap in the bay even.
I've taken it to bits and it was so filthy inside, so hopefully that all it is. I'm gonna order repair kit and will keep this thread updated with progress.
Thanks
Thanks
- hightower666
23 May 2014 01:42
I snapped the circlip on the outside, so will need a new one.
Does anyone know whether I should get a new circlip in the pack I've ordered, and if not what size it is so I can order a new one?
- hightower666
27 May 2014 06:51
So just rebuilt starter but all I got was a spark and not much else. Sure I've built it properly, but obviously not - can anyone help
- hightower666
16 Jun 2014 12:26
Pulled it to bits again, used the old brushes and works a treat. New brushes were slightly different so must have caused an issue. Plenty left on old bushes anyway - about 10mm long, service limit is 6mm according to manual.
Check out my blog in my sig for a video of me firing it up for the first time.
