Difference between starter motors
  • MagnusMax
  • MagnusMax's Avatar Topic Author
30 Apr 2014 17:59
#630958
My bike is a 1983 Spectre, (KZ750 N2). Unfortunately, when I bought it, it came complete with a burnt out starter motor. I don't think there's any rebuilding of this sucker, everything inside looks pretty much melted. Problem is, where on earth do I get a new starter? There are a few on ebay, but looking at Partzilla's Kawasaki parts interchange information, it looks like the 1983 Spectre 750 takes a 21163-1025 starter motor. The only other models with this motor were the 1982 Spectre and the 1983 LTD Shaft. Most of the other KZ750s from this era seem to take a 21163-1190 motor. Are the differences between these two motors real? Or is it one of those cases where they painted it a different color and gave it a new part number to match? Any suggestions?
Magnus
1983 KZ750 Spectre
  • ZERO
  • ZERO's Avatar
Re: Difference between starter motors
01 May 2014 02:34
#631003
From what I recall, and it's been a while...Is that the earlier Z-1 type starters will fit the later "J" type engines. The weak part was always the starter clutches and not the starter. (but yours is melted) The very early motors had the wires as part of the assembly and a little later on they had the wire held on with a stud and nut. I seem to remember swapping them out without issue.
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
The following user(s) said Thank You: MagnusMax
  • Nebr_Rex
  • Nebr_Rex's Avatar
01 May 2014 04:50
#631007
ZERO wrote: From what I recall, and it's been a while...Is that the earlier Z-1 type starters will fit the later "J" type engines. The weak part was always the starter clutches and not the starter. (but yours is melted) The very early motors had the wires as part of the assembly and a little later on they had the wire held on with a stud and nut. I seem to remember swapping them out without issue.
O.P. has a 750 not a 1000.
Any KZ650 or KZ750 starter will work.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • MagnusMax
01 May 2014 10:30
#631040
Thanks guys, I'll give it a shot. Worst case I'm out $75 and have to keep looking. I wasn't sure whether the shaft drive placed some unusual demands on the starter or something. (I'm a clueless newb and have zero experience working on these bikes.)
1983 KZ750 Spectre
  • StreetfighterKz
  • StreetfighterKz's Avatar
01 May 2014 10:33
#631042
I put an early 2000's Zr7 starter in my '83 Gpz750. No issues yet. Plus it's newer and has less wear on it.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • loudhvx
  • loudhvx's Avatar
01 May 2014 12:56
#631056
StreetfighterKz wrote: I put an early 2000's Zr7 starter in my '83 Gpz750. No issues yet. Plus it's newer and has less wear on it.
Later, Doug
Gotta love it when kaw makes things compatible.
  • MFolks
  • MFolks's Avatar
01 May 2014 14:29
#631062
