- Thank you received: 5
Changed my plugs
- djturnz
23 Apr 2014 17:33 #630124
by djturnz
1982 KZ750 (4) LTD
Changed my plugs was created by djturnz
I decided after three seasons to change my plugs. I bought B8es plugs. What I pulled out were BR 7ES. The wires are NGK. Should I have replaced them with a resistor plug?
1982 KZ750 (4) LTD
- Thank you received: 2829
23 Apr 2014 17:59 #630127
by 650ed
No. But why did you change to a colder plug? When I had colder plugs in my KZ650 they fouled. Ed
Replied by 650ed on topic Changed my plugs
djturnz wrote: I decided after three seasons to change my plugs. I bought B8es plugs. What I pulled out were BR 7ES. The wires are NGK. Should I have replaced them with a resistor plug?
- djturnz
23 Apr 2014 18:06 #630128
by djturnz
1982 KZ750 (4) LTD
Replied by djturnz on topic Changed my plugs
I read that 8 was preferred for all around riding, and 7 were for slow riding in town. Would it make a difference if my bike was always loaded down with heavy cargo?
1982 KZ750 (4) LTD
23 Apr 2014 18:11 #630129
by 650ed
I don't know. You may want to check them after a hundred miles or so to see if they are black with soot compared to the old ones they replaced. Ed
- Motor Head
- Thank you received: 391
23 Apr 2014 19:26 - 23 Apr 2014 19:30 #630142
by Motor Head
Replied by Motor Head on topic Changed my plugs
With NGK, the lower the # the Hotter. So 7 is hotter than 8, 9 would be colder than 8.
Non Resistor plugs should be used. So No "R" in the part # with NGK. The resistor plugs would have lowered your spark output, which would make them darker, giving a false plug reading.
Back to the stock plugs, which are non Resistor, would be my choice.
Last edit: 23 Apr 2014 19:30 by Motor Head.
- djturnz
24 Apr 2014 01:35 #630166
by djturnz
1982 KZ750 (4) LTD
I didn't think they should be resistors. I guess I didn't realize that was what I had in there for three years.
I assume the look of the old plugs doesn't mean much since they were in so long and were wrong.
Its not shown well in the picture, but the white its actually slightly tan and they are in order left to right as you sit on the bike.
1982 KZ750 (4) LTD
