Need new 14 mm spark-plug crush washers
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
23 Apr 2014 09:07
#630073
After pulling spark plugs several times to examine, the washers have crushed beyond usefulness, but the spark plugs are great and have lots of life left.
Is there an on-shore supplier of cheap 14 mm replacement crush washers that anyone knows of?
Found UK supplier (not cheap). Seems like a no-brainer thing to find...but nothing. :unsure:
1982 KZ1100-A2/1170 sleeper 😀
  • Dr. Gamma
  • Dr. Gamma's Avatar
Re: Need new 14 mm spark-plug crush washers
23 Apr 2014 09:30
#630076
The oil drain plug washer on the 1986/1987 GSXR750's is exactly the same crush washer that is used on all the 14mm NGK spark plugs.
The crush washer from Suzuki might cost you almost as much as a new NGK spark plug.
1986 RG500G 2 stroke terror.
  • daveo
  • Premium Member
  • Premium Member
23 Apr 2014 09:49
#630077
Dr. Gamma wrote: The oil drain plug washer on the 1986/1987 GSXR750's is exactly the same crush washer that is used on all the 14mm NGK spark plugs.
I'm getting somewhere now...seems the answers come out of nowhere, once a question is asked. :huh:
For anyone interested, I'll post the solution after getting more supply/availability information.
