No starter button/where to send coils to? 80 kz650
- Jasonhasakz
11 Apr 2014 09:27
Greetings from Lake Michigan.
In my attempt to make my first cafe racer, I have dropped my right side controls. The starter button was broken when I bought the bike, so dropping the controls wasn't a huge sacrifice (plus, i liked the idea of kickstart only...maybe a newbie decision). So that leaves me with the yellow coil wires that would have went to the starter button, Should they go straight to the ignition now? I'm lost. HELP!
- loudhvx
Re: No starter button/where to send coils to? 80 kz650
11 Apr 2014 10:14
The yellow coil wires didn't go directly to the starter button. They would have gone to the kill switch where they would have gotten 12v. But now you need to connect them to the switched 12v supply wire coming from the ignition switch (key switch).
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: Jasonhasakz
- Jasonhasakz
11 Apr 2014 10:49
Thank you! That is what I did, I just wanted to make sure that it would work. Thanks again
