STRANDED, please help!
  • anotherZ
  • anotherZ's Avatar Topic Author
09 Apr 2014 17:00
#628459
So I am stranded with what I believe is because of an overcharging issue. After 150 miles at 75 mph, bike died, battery was very hot, zero voltage. After the batt cooled down, now I have a voltage of 16 volt, Fuses not blown but none of the light etc work. Bike is a 79 ltd 1000. Currently in Lebanon, MO, 1,000 mls away from home. Towing called but any advice appreciated, need to getit fixed somehow....
79 KZ 1000 LTD
Saved it from becoming a drag bike
Smaller tank
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: STRANDED, please help!
09 Apr 2014 17:27
#628464
Nothing you didn't already know but you need a new voltage regulator and probably a new battery.
Perhaps somebody closer will chime in.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • anotherZ
09 Apr 2014 18:03
#628468
Ok thx. Can someone tell me how to test the regulator (and which one is te regulator and which one the rectifier), also if I just get a replacement that won't solve the overcharging issue, any recommendations? Should I get one of those combined reg/rec.? Thanks everyone, need a beer now.....
79 KZ 1000 LTD
Smaller tank
  • peter1958
  • peter1958's Avatar
09 Apr 2014 18:09
#628470
Another battery at walmart for 40.00 would get you home.
  • anotherZ
09 Apr 2014 18:36
#628474
I am 1,000 mls from home....can someone give me a link where I can see how to test it?
79 KZ 1000 LTD
Smaller tank
  • nickleo373
  • nickleo373's Avatar
09 Apr 2014 19:56 - 09 Apr 2014 20:37
#628487
www.partzilla.com/parts/search/Kawasaki/...-%2780+A3/parts.html
This should show you what the reg/rec looks like
1981 KZ550C LTD
"If you ain't first, you're last"
Last edit: 09 Apr 2014 20:37 by nickleo373.
  • nickleo373
09 Apr 2014 19:57 - 09 Apr 2014 20:30
#628488
These videos will take you through how to test the whole charging system
1981 KZ550C LTD
Last edit: 09 Apr 2014 20:30 by nickleo373.
  • Old Man Rock
  • Old Man Rock's Avatar
10 Apr 2014 04:18
#628517
hope this helps to get you going.... Good luck!
This was written for the KZ900 where '79 should be~ the same in T-shooting anyways.
Attachment KZ900ElectricalTests.jpg not found
Unknown if you have points or EI ignition setup so adding just in case....
Attachment IgnitionCoilTesting.jpg not found
Attachment KZ900RectifierTegulatorSchematic.jpg not found
Attachment ElectricalTroubleShootingOEMGuide.jpg not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Old Man Rock
10 Apr 2014 04:22
#628518
easier to read image 1..
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • 80B4
  • 80B4's Avatar
10 Apr 2014 06:13
#628536
I have had very good luck with parts from these folks. They even provide a 1 year warranty on their electrical parts. Their diagnostic flow chart is good too.
www.electrosport.com/technical-resources/
1980B4 1000
1978 Z1R
1978 B3 750
  • anotherZ
10 Apr 2014 06:45
#628538
Thanks guys, Headed back to my bike now. Z1enterprises told me they can overnight a reg/rec to me, so will run some tests this morning and hope I can figure it out. Wish me luck!
79 KZ 1000 LTD
Smaller tank
  • kaw-a-holic
  • kaw-a-holic's Avatar
10 Apr 2014 07:23
#628543
Good luck sir! Let us know if you "rectify" the issue and that you got home same. Ride safe.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
