lost key
- eric77kz
lost key
30 Mar 2014 19:12 - 30 Mar 2014 19:40
Just as it sounds. Can not find the keys to my 77 kz650. Of course this means no starting, gassing up or raising my seat. Suggestions?
My fiance has an 85 rebel with no ignition and gets turned by the way of a screwdiver. How did these people do this? Promise, no foul play about. Just want to get my bike running.
77 KZ650 C
Last edit: 30 Mar 2014 19:40 by eric77kz.
Re: lost key
30 Mar 2014 20:19
No eBay APP ID and/or Cert ID defined in Kunena configurationTake a really close look at your seat lock. Next to the keyhole you should see a 3 digit number. It should begin with an "8". Assuming the seat, ignition, and fork lock are all original, the Kawasaki key with that 3 digit number should fit all 3 locks. Any key will fit the fuel tank lock as it has no pins inside. The eBay guy below has a bunch of different KZ keys. If he has one that matches the number on your lock it should work. Ed
The following user(s) said Thank You: eric77kz
Re: lost key
31 Mar 2014 03:11
www.kzrider.com/forum/4-electrical/41487...y-by-the-code-number
Could consider a PM to rstnick .
- lightitup
Re: lost key
31 Mar 2014 07:06
rstnick does great work all i had to was give him the code on the lock and he sent me a prefect key
81 kz 550 ltd
- eric77kz
- slayer61
- KZR FLAG RELAY CARRIER #62
Re: lost key
31 Mar 2014 14:56
rstnick is a member here. Patton also gave you a link to a series of posts regarding replacing lost keys written by
rstnick
good luck.
good luck.
- eric77kz
- pete greek1
Re: lost key
23 May 2014 13:25
Is there a way to open the seat so I can remove the lock ? hav'nt seen the key for my 76 LTD 900 in 2 1/2 yrs. while I've been buying all kinds of parts for it, so yesterday I decide to go out & start fiddling with it & ended up spending the whole day trying to find the key, so I gave up & went to a lock & safe place that said they could make a key if I get the 3 digit # from the seat lock , it's 751, he made me 2 keys for 23.00, I get home & they don't work....what other options do I have, I called another place that will come out to me to make a key but they want 95.00, WTF !!!
Pete
Pete
- eric77kz
Re: lost key
23 May 2014 13:50
I lost a patience and ended up drilling mine out. Then I ordered a new ignition from Z1 Enterprises.
77 KZ650 C
- Cynjut
