Possible starter clutch problem? 1978 KZ750B
  • pazzadelivery
  • pazzadelivery's Avatar Topic Author
29 Mar 2014 21:29
#627055
I put a new battery in my '78 KZ750 and it turns the engine over. However, it sounds awful like a kind of whiny grinding noise and kind of sluggish too. Today, I stalled the bike a few times (I am a new rider), and the electric starter just would not turn the engine. It was really sluggish sounding. I ended up just using the kick start. I am wondering if this is the starter clutch, or a problem somewhere else in the bike.
I want to fix this issue without throwing a whole lot of parts at my bike if they are not the problem. Where is this starter located on the bike, and is there a good way to check it?
  • bountyhunter
  • bountyhunter's Avatar
Re: Possible starter clutch problem? 1978 KZ750B
29 Mar 2014 23:39
#627063
Whining and grinding does sound like a startr clutch problem. A slow crank/tired crank is either battery or starter motor.
  • bountyhunter
29 Mar 2014 23:42
#627064
Starter clutch fail is common on the 750 twin. It's under the flywheel, left side of engine. Not too bad to change.
The following user(s) said Thank You: pazzadelivery
  • pazzadelivery
30 Mar 2014 09:49
#627099
It looks like you have a similar model bike. Have you ever replaced your starter clutch before? I want to buy one online that won't be a lemon.
30 Mar 2014 11:16 - 30 Mar 2014 11:24
#627108
Last edit: 30 Mar 2014 11:24 by Patton.
  • bountyhunter
30 Mar 2014 17:38
#627146
pazzadelivery wrote: It looks like you have a similar model bike. Have you ever replaced your starter clutch before? I want to buy one online that won't be a lemon.
I took mine off and inspected it, assuming it might be bad...... so I had purchased a good used one offline to have parts if needed. Didn't need the new one, so I sold it to somebody.
There are a lot of bike dismantlers online who sell decent parts. I think I paid $80 for the used one with all parts, chain, gears and everything.
  • bountyhunter
30 Mar 2014 17:42
#627148
