Help! Dyna s ignition.
  • Geeebeee
  • Geeebeee's Avatar Topic Author
29 Mar 2014 16:21
#627025
Hi all, I am progressing well with fixing up my 1980 kz ltd. And currently going over the wiring loom and checking bits and pieces, P.O has done lots of suspect work. My current issue is that I removed the plate with pick up/pulsing coils mounted on it and did some replacement of cabling ( Due to multiple poorly done joins etc.) I tested the ohms on both before beginning and they were ok 450 app. However after replacing cables one coil is showing open circuit even when tested right at where the cables enter the unit itself. I suspect this pulsing coil was at the point of failure anway.
My question is can I buy replacement after market pick up coils anywhere as they are listed as obselete. Or alternatively can I buy and fit a dyna s replacement unit (are they available for my model?). And is there anything I should be aware of when swapping out.
I am based in Australia so will have a wait on delivery.
Thanks in advance and here is a pic of my bike, nearly finished and very anxious to get it running now.
Greg
1980 kz550 c ltd.
1982 GPZ750R
Re: Help! Dyna s ignition.
29 Mar 2014 18:51
#627038
Dyna-S is the quick and easy remedy, and doesn't use the igniter (which might also be or become a suspect component).
The stock ignition is a good design, but purchasing any used replacement parts for it would be a crap-shoot.
Z1 Enterprises is a good source for Dyna-S, and would also get a set of the Dyna solid core plug wires with integrated caps, and new ignition coils.
The Dyna-S likely requires higher ohm ignition coils than the stock coils used with the stock igniter ignition. The green 3 ohm Dyna coils are recommended.
However, Z1E also has less expensive 4 ohm ignition coils that will serve just fine, and which I believe have integrated plug wires that also require caps.
Very reasonable pricing and best service on the planet:
www.z1enterprises.com/
Good Fortune! :)
29 Mar 2014 18:59 - 30 Mar 2014 08:27
#627039
Per kawasaki.com, the "pulsing coil" assembly part number [strike]59026-1012 was used on various Kawasaki models through 1995.[/strike] is 59026-1009.
Can google the part number to locate a source.
[strike]Here's a sample:[/strike]
[strike] www.partzilla.com/parts/detail/kawasaki/KP-59026-1012.html [/strike]
Good Fortune! :)
EDIT -- correct part number is 59026-1009
www.partzilla.com/parts/detail/kawasaki/KP-59026-1009.html
Shows "Not Available."
Last edit: 30 Mar 2014 08:27 by Patton.
The following user(s) said Thank You: Geeebeee
  • Geeebeee
29 Mar 2014 19:47
#627044
Thanks Patton,
I remember checking partzilla the other day and thought my part no. Was 59026-1009 did a quick check on eBay at the time and did not show much. I am currently at work - working hard:-) so will do some more research tonight , thanks again for your informative responses and I suspect I may have to go the dyna s option, I will check my coil rating tonight.
1980 kz550 c ltd.
1982 GPZ750R
  • kaw-a-holic
  • kaw-a-holic's Avatar
29 Mar 2014 19:47
#627045
Patton wrote: Per kawasaki.com, the "pulsing coil" assembly part number 59026-1012 was used on various Kawasaki models through 1995.
Here's a sample:
Good Fortune! :)
$108? I would replace with Dyna S.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
29 Mar 2014 20:28 - 29 Mar 2014 20:37
#627049
Geeebeee wrote: Thanks Patton,
Opps :blush: 59026-1009 is correct.
Partzilla says "Unavailable," as do several other suppliers.
Good Fortune! :)
Last edit: 29 Mar 2014 20:37 by Patton.
29 Mar 2014 20:56 - 29 Mar 2014 20:57
#627053
If needed, a service manual may be downloaded, courtesy of KZr Member loudhvx.
General
home.comcast.net/~loudgpz/GPZweb/index.html#home
Service manuals
home.comcast.net/~loudgpz/GPZweb/Mnls/Mnls.html
The manual at hand shows:
Good Fortune! :)
Last edit: 29 Mar 2014 20:57 by Patton.
  • Geeebeee
29 Mar 2014 21:51
#627056
Thanks, I have a kawasaki service manual and have used many of the links in loudvhx signature already to help me get this far, along with the wealth of knowledge from the regular contributors to this forum.
1980 kz550 c ltd.
1982 GPZ750R
  • Old Man Rock
  • Old Man Rock's Avatar
30 Mar 2014 06:25 - 30 Mar 2014 06:28
#627076
Somewhat confused, Title depicts a Dyna-S ignition or is this the stock ignition... ?
Is your frame -> engine optimally grounded (battery (-) potential....?
Ignition plate ground is through the plate to engine contact...
If Dyna components, have you performed the static test...?
Will inform you if pickups are working or not...
In case you need...
Dyna S Installation-testing
Dyna Tek Test Procedure
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 30 Mar 2014 06:28 by Old Man Rock.
  • turboking
  • turboking's Avatar
30 Mar 2014 07:54
#627084
No eBay APP ID and/or Cert ID defined in Kunena configurationI would install a dyna s....... :ohmy:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
30 Mar 2014 08:30
#627090
Here's the Dyna-S listing at Z1E:
www.z1enterprises.com/ItemDetails.aspx?i...0%2f750&item=DYDS2-2
Good Fortune! :)
  • Geeebeee
30 Mar 2014 12:50
#627111
Sorry for creating confusion, my bike currently has the stock transistorised ignition system fitted however one pulsing coil has failed creating the need to get replacement original part (obselete) or switch to the dyna s system.
I chose the title dyna s for the post in order to attract responses from those who have used these or have advice on using.
I have done a test on my coils and get a reading of 3 ohms , they may have been replaced with coils from another model? So I will go ahead and order a dyna s unit today.
Thanks again everyone.
1980 kz550 c ltd.
1982 GPZ750R
