Fuse Box (main fuse relay)
- Spectre06
19 Mar 2014 15:57 - 19 Mar 2014 16:00Attachment fuzebox.jpg not found
Hello all,
I am trying to determine the correct fuse sizes for my KZ750 N1 Spectre. All fuses were removed when I acquired the bike. Specifically what size fuse goes in the first slot from top, 2nd from top, 3rd from top etc. I do not want to use a fuse that is higher than it should be and damage the bike. See file for clarity.
Thanks
Last edit: 19 Mar 2014 16:00 by Spectre06. Reason: add file
- MFolks
Re: Fuse Box (main fuse relay)
19 Mar 2014 19:50
If you can tell us what the fuses are for(i.e. headlight, main, horn etc.) we can help. Is the translucent fuse cover there?
20 Mar 2014 07:38 - 20 Mar 2014 07:43
The fuse box for my 81 KZ650 has info embossed below the fuses.
Your Spectre may be the same, so remove the fuses & take a look.
The diagrams at Kawasaki.com will have the fuse sizes, so that might be helpful.
From the chasis elec equip diagram, I'd guess the bottom fuse is a 30A (L=25mm) &
the other ones are 10A (probably 25mm as well). The fuses in the aux fuse box are 10A
but they are longer (L=30mm or 1-1/4").
If you need a manual, which will have a wiring diagram, search eebbaayy for KZ750 Shaft Manual. They're usually readily available for the Shaft drive 750.
Last edit: 20 Mar 2014 07:43 by martin_csr.
