79 kz400 battery needed?
  • shawn stangel
  • shawn stangel's Avatar Topic Author
19 Mar 2014 13:01 - 19 Mar 2014 13:02
#625779
i have purchased a 79 kz400 and was wanting to get rid of the battery,and just use the kickstart but my buddy tells me it cant be done,looking for advice on this thanks
Last edit: 19 Mar 2014 13:02 by shawn stangel.
  • MFolks
  • MFolks's Avatar
Re: 79 kz400 battery needed?
19 Mar 2014 14:08
#625786
  • martin_csr
  • martin_csr's Avatar
Re: 79 kz400 battery needed? --- Capacitor
19 Mar 2014 14:57
#625793
Try searching KZR for capacitor. I think you'll need an on/off switch for the headlight when starting the bike.
  • loudhvx
  • loudhvx's Avatar
19 Mar 2014 16:17 - 19 Mar 2014 16:19
#625803
Since your bike has a permanent magnet alternator, it should work without a battery.
Like martin says, however, you will need a capacitor to replace the battery.
look for 5000 microfarad to 10,000 microfarad, 50volt capacitor.
Microfarad might be "MFD", or "uF", or "uFD".
Or you can buy one of those battery eliminators. It's just capacitor.
Then if the regulator has a brown wire coming out of it, connect that brown wire to the red wire of the regulator, (and leave the brown wire on the harness side unconnected and taped up).
Then you will need to be able to switch all of the lights and accessories off while starting.
An efficient ignition system helps too. If you are considering an electronic ignition, try to get a factory one frm a KZ440.
But before you do any of that, tune the bike with a battery and make sure it starts in one or two kicks almost everytime. If it's hard to start. It will only be harder without a battery.
Last edit: 19 Mar 2014 16:19 by loudhvx.
  • shawn stangel
Re: batpac
08 May 2014 14:10
#631835
i just recieved my batpac in the mail (battery eliminator).is anyone familiar with this ? wanting to know if i need to put a switch on my headlights andt urnsignals or just headlight or none needed? thanks
  • shawn stangel
08 May 2014 14:13
#631836
will i need a switch to shut the headlight ooff and the turn signals or just headlight or neither i bought the Batpac.
  • loudhvx
  • loudhvx's Avatar
09 May 2014 00:26 - 09 May 2014 00:28
#631895
Do you mean the marker lights that are on all the time? The tun signals already have a switch.
The marker lights and tail light, along with the gauge lights will all take away current from the capacitor. It means you will have to kick harder to get it to start if at all, so it would be best to rig a switch to kill all of those lights.
I use a self-holding relay to automatically turn the lights off if the bike stalls. Then you won't be fumbling with switches at an intersection to restart it. I use the starter button to turn the relay on to turn the lights on after it is started.
Last edit: 09 May 2014 00:28 by loudhvx.
