Open up Tach and Spedo on 77 KZ1000
- chconger
I would like to be able to clean some crud on the inside glass of my "clocks" (as they say in the UK.)
Is there a trick to opening these things up? I have the backs off but that only exposes the connectors for the lamps. To go deep inside it appears I need to bend open the crimped ring on the outside? Looks impossible to open without damaging the ring...?
I hope there is a simple secret to this...?
Thanks
Chris
1977 KZ 1000-A
- Grumpy Ole Artist
- Eschew Obfuscation!
- Thank you received: 62
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
- kaw-a-holic
- Thank you received: 249
chconger wrote: Hi Guys
Thanks
Chris
Chris,
Here is a link from a quick search in the forum.
www.kzrider.com/forum/5-chassis/592799-8...lens-cleaning#623132
There is a link on the last past on how to take them apart. From what I have read, it is not an easy job, lots of patience is required. Once you get them apart you have to be careful removing the needles. An old trick is using 2 spoons from the kitchen, one on each side. Caution! The needle and other bits may depart the gauge quite rapidly so a spotter is advised. The rings are never the same again. A special machine is used to put them on during manufacturing. Resto.com I believe will do this for you, but its not cheap. They do quality work.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- Thank you received: 2098
Click > www.zresto.com/
Here's a diy option from an earlier thread ---
duncan wrote:
i've taken the tach apart but not the speedo. it's real easy if you use a dremel to cut the chrome ring, and then some jweld and hose clamp to cement it back together.
apeman wrote:
The old article suggests removing the band around the gauges by levering it up from the underside. I have found that results in too much damage to the band to make it look good after it is put back on, and crimped down. Therefore, I instead took a dremel with a cut-off wheel to the band, and sliced through it, being carefull not to damage the gauge cover. Then I slipped off the band, and did my gauge clean-up. To reinstall, I assembled the cover onto the gauge, slipped the band on, and held it tightly in place with a rubber band. Then I placed a drop of JBweld epoxy onto the gap in the band, and let it dry. (Make sure you mount the gap in the band at an location that will not be readily visible when the gauge is remounted onto the bike.) That has been working well for over a year.
- chconger
As I feared, the problem is getting the ring off and back on without butchering it. Looks like z-resto has refined some tooling to do this properly; but $95 a pop is not in this years budget.
Crud on my glass is not looking so bad all of a sudden....
Cheers
Chris
1977 KZ 1000-A
- Z1Driver
- love the smell of triple smoke
- Thank you received: 55
Blue 1975 Z1B
Red 2009 Concours 14
- spdygon
- Thank you received: 117
most charge 90 for the restore and extra for extra parts and labor. if your gauges need parts it will total up preety quick.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
- jakedude
- Thank you received: 30
Nothing lasts, nothing is finished, and nothing is perfect.
- asphalt900
- Thank you received: 274
- pete greek1
- Thank you received: 185
- undiablo
- Thank you received: 64
asphalt900 wrote: If it helps, here is another way to open the clocks. Simple hand tools modified to use for this practice. A piece of PVC 4" pipe milled out to hold instrument, needle-nose pliers, flatblade screwdriver, tape, old Kaw Sprocket and Patience. Been doing these for years, way before the aftermarket faces/overlays were available. Never have had to cut the ring. No Spoons to pull-up the needle. The spoon trick is actually a Bad idea. Two E-clips are all that hold the needle shaft in alignment. Loading these e-clips can cause unseen damage. Hold the Drag-Cup off its resting limiter and Twist to loosen while pulling away from face. If reusing face, trim your fingernails to prevent scratching face or use painters tape. The sprocket is actually a Perfect fit for the Upper Can. The cut-out notch is for the crimping tool. This might be a bit too involved if you are only doing a single set but it's on the cheap. Plus it's fun to experiment! Then you can start Painting your Original Faces! Clay
Sorry, I don't understand what is the sprocket for. Could you explain a little mote?
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- asphalt900
