Bear essentials electric plan
- jsnabbs
- 1981 kawiKZ440
17 Mar 2014 02:22
Does anyone have any info,link,PDF to a bear essentials electric plan?
I have no idea when it comes to electrics, i will be having someone wire everything up for me when i come to that point.
What i need to know is what do i need to make space for in my electrics tray that im having fabed up?
This is the battery i will be using, from the pictures you can see it will have a little box to hold it
shoraipower.com/lfx14a2-bs12-p66
What i think i need to run....
Coils
Electric start
Headlamp H/L
LED Blinkers
Rear Brake
like i said i have no idea what needs to fit in here so please, do tell.
Here is the mock up for the tray
Coils
Electric start
Headlamp H/L
LED Blinkers
Rear Brake
Attachment electray.jpg not found
Attachment electray2.jpg not found
Attachment electray3.jpg not found
TIME TO TRADE IN THE PEDALS FOR SOME POWER
Re: Bare essentials electric plan
17 Mar 2014 06:23 - 17 Mar 2014 14:18
You'll need a voltage regulator/rectifier to keep the battery charged.
Also, you'll need an igniter.
You may not consider this a bare essential, but I would have a brake indicator light on the instrument cluster, and I would also wire in an outage indicator switch to act as a warning light to let you know that there is a problem w the brake light... getting rear ended is one of those things I'd like to avoid.
KZR topic --- Brake Light Problem
A neutral light is something else I would have as well.
Last edit: 17 Mar 2014 14:18 by martin_csr.
The following user(s) said Thank You: jsnabbs
- jsnabbs
- 1981 kawiKZ440
Re: Bear essentials electric plan
17 Mar 2014 08:37
So if someone has a plan for me that would be great, something along the lines of this but not sooo stripped back
www.google.de/imgres?imgurl=http://i265....0CDwQ9QEwBQ&dur=4669
many thanks
many thanks
- slayer61
- KZR FLAG RELAY CARRIER #62
17 Mar 2014 12:50
loudhvx does a lot of these for folks. Have a look at a thread titled "1980 750H bare bones for mattylight" or just click
HERE
Good luck with your project!
- jsnabbs
- 1981 kawiKZ440
17 Mar 2014 13:56
Thnaks for the elecrics plan, big help.
i know this is hard to guess, but do you guys think i have left enought space in the mock up tray for what i need?
- loudhvx
17 Mar 2014 14:23
If you are going bare bones, you really only need room for a battery, regulator/rectifier combo unit, and maybe a fue or two. But I would recommend leaving enough room for two reg/rec combo units. Then you will have room for an igniter in case you want to get rid of the points and use a factory system.
There should be plenty of room for all of that between the frame rails, under the seat.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- 331lxstang
17 Mar 2014 15:29
Type in (evan fell simple wiring diagram) on the net. Its a godsend for anyone wiring a bike, with a little browsing on his site you can wire just about any bike.
1977 Santee hardtail, 1075 Andrews 3x cams, old school
1978 KZ 1000 under restoration to original
