Alternator Rotor Condition
- daless
10 Mar 2014 17:16
I've been chasing both a voltage drop and charging issue. Just wanted to see if anyone had any comments on the condition of the rotor while i have it easily accessible, before I tighten it down with a new gasket and fill up on oil.
Are scrapes like that a huge deal? There are some smaller ones on the other sides. The magnet still seems to be strong, although I'm not really sure how strong strong should be here.
Attachment IMG_20140310_164533.jpg not found
Attachment IMG_20140310_164732.jpg not found
'77 KZ1000A1 - Mikuni VM29s, Kerker 4-1, K&N pods, LTD mags, Z2 seat
- steell
Re: Alternator Rotor Condition
11 Mar 2014 13:59
I don't see anything wrong with using it.
- MFolks
11 Mar 2014 14:56
See any burned spots on the stator(the wire windings)? Did you use a multimeter to ohm it out? Check from any of the three phases to ground too.
