New tail light/turn signal
  • schmjj01
  • schmjj01's Avatar Topic Author
08 Mar 2014 14:24
#624540
Ok for the life of me for some reason I can not figure this out...
Can anyone help me with how to wire a new tail light/turn signal assembly on my 82 KZ550c? The new assembly has 5 wires (red, black, green, yellow and whit) my bike has seven wires (black/yellow, blue/red, green for tail lights and green, tan and two black/yellow). I got it to were I can make the new assembly light up but it will not get brighter for braking. I would appreciate any help I can get on this. I think I'm just having a bad day but getting frustrated and thought id just ask for some help. Thank you
1982 KZ550 c LTD no modifications done yet!
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: New tail light/turn signal
08 Mar 2014 15:18 - 08 Mar 2014 15:19
#624550
I'm going strictly from memory and not sure exactly what wires do what on your light (no idea what light you are using or where you got it) but....
Black/yellow > Black (Ground)
Blue/red > ? (Brake light)
Brown > ? (Tail/running light)
Green > ? (L or R turn signal)
Grey > ? (other turn signal)
2 black/yellow (not used, were separate signal grounds)
Not sure if that helps or not.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 08 Mar 2014 15:19 by StreetfighterKz.
08 Mar 2014 16:25 - 08 Mar 2014 16:31
#624553
Here's a link to the wiring diagram in KZr's FILEBASE:
www.kzrider.com/filebase/search/finish/1-general/281-z550c3
Good Fortune! :)
Last edit: 08 Mar 2014 16:31 by Patton.
  • MFolks
  • MFolks's Avatar
08 Mar 2014 19:29
#624572
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
  • bountyhunter
  • bountyhunter's Avatar
08 Mar 2014 20:33
#624579
schmjj01 wrote: Ok for the life of me for some reason I can not figure this out...
My guess is that black is ground, and the other four wires are:
power tail running lamp
power tail brake lamp
power left turn
power right turn
08 Mar 2014 21:23 - 08 Mar 2014 21:25
#624582
schmjj01 wrote: ... I got it to were I can make the new assembly light up but it will not get brighter for braking....
There should be a brown wire (hot) into the rear brake switch, and a blue wire from the switch to the brake light filament in the rear bulb.
When the brake pedal is pressed down, it's supposed to activate the rear brake switch, which connects hot brown > blue > rear bulb brake filament > black/yellow > ground.
[It'll be okay for OMR to tell us all how much he loves this illustration. :laugh: ]
Good Fortune! :)
Last edit: 08 Mar 2014 21:25 by Patton.
