Battery Acid Level indicator
  • Spectre06
  • Spectre06's Avatar Topic Author
05 Mar 2014 11:26
#624252
Hello all,
I just got a 1982 KZ750 N1 Spectre. It needs a lot of work and is missing a few parts (brake pedal, shift pedal, pegs, entire headlamp assembly other small items.). I am attempting to get it started and wanted a little direction. I have purchased a new battery and will hook it up today. I was looking at a manual and there is supposed to be a sensor that plugs into the battery to indicate the charge. That part is missing and I could not figure out if it is necessary or if it can be left off. Any suggestions will do. Also, since the bike has sat for several years, was looking for a list of "must do first's" to get it started. My plan was to remove and clean the carbs, fill it with oil, jerry rig a fuel source and give it a try. Thoughts? Thanks in advance.
Re: Battery Acid Level indicator
05 Mar 2014 11:33
#624254
If it's been sitting for years you may want to remove the cam cover and put some oil on the cams and top end. Also, it probably wouldn't hurt to spritz some lube through the spark plug holes onto the cylinder walls which may be bone dry. Ed
  • turboking
  • turboking's Avatar
05 Mar 2014 11:50
#624257
you can run it without it :dry: .... :huh: the lamp will remain lit......remove the bulb if it bothers you....... :S
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • bountyhunter
  • bountyhunter's Avatar
05 Mar 2014 12:51
#624260
Spectre06 wrote: Hello all,
Drain the oil and replace with clean oil. Take the spark plugs out and use the kick starter to turn the engine over for about five minutes to get the engine pumped up full of oil.
Take the gas tank off and dump and rinse with clean gas or solvent.
  • koolaid_kid
  • koolaid_kid's Avatar
05 Mar 2014 13:03
#624264
The wire went to a sensor in the battery, no longer supported. Just wire it to a 12V wire, which is hot when the key is ON and you will be fine.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • Spectre06
05 Mar 2014 16:04
#624279
Thanks all.. Will take the advice. Ran into another problem.. the fuze box is missing fuzes and the size/amp is not listed in the box so I am not sure which size fuzes use as replacements. Any suggestions?
  • uncle nick
  • uncle nick's Avatar
06 Mar 2014 12:52
#624355
If I was you I'd try to find some-one with the same bike and ask them.
There's a guy on here, Spectre 1982, maybe worth a try.
Good luck :)
1981 KZ650 CSR
  • loudhvx
  • loudhvx's Avatar
06 Mar 2014 12:58
#624357
After you get the bike running and looking good, you will likely want to get an AGM sealed battery to prevent acid spills corrosion etc., so you won't need the acid level detector.
Wire it like Koolaid said, and you'll be good to go.
