What gauge wire is the starter cable?
- HAFROD
04 Feb 2014 10:24
What is the gauge size of the main starter wire going from starter to solenoid? The sizes look the same on my KZ550 and my KZ1000
Two 1983 GPz 305's, 1984 GPz550, 1980 KZ550A, 1978 KZ1000A2A
- 4TheKZ1000
Re: What gauge wire is the starter cable?
04 Feb 2014 10:40 - 04 Feb 2014 10:50
I bumped mine up to 6 gauge on both Postive and Negitive wires.
Stock is 8 gauge.
14 gauge for regulator wire.
Stock is 8 gauge.
Last edit: 04 Feb 2014 10:50 by 4TheKZ1000.
- MFolks
04 Feb 2014 13:11
For much better current flow(amps), go up to 6 AWG (American Wire Gauge) welding cable, as it's more flexible. You'll need the correct wire terminals, with the proper hole sizes for this "Upgrade".
I've got one of these, they are a little pricey, but I can make my own larger gauge cables for my car or bike: www.harborfreight.com/catalogsearch/result?q=hydraulic+crimper
- wireman
10 Feb 2014 10:03
The fine strands of copper in the welding lead make it really good for battety cables, ive seen batteries that were almost dead flat whip over a starter with those cables.
- Jeff.Saunders
10 Feb 2014 13:59
6wg or 4wg
www.z1enterprises.com
Z1 Ent on Facebook,
