'81 kz550 ltd, ignition coil wiring help
- Calebjkd
02 Feb 2014 23:05
Right in the middle of wiring up my 1981 kz550 ltd and I'm not sure what to do.
Made it to the ignition coils and not sure how to wire them.
Which wire goes to the + terminal?
The green/black wires coming from the ignitor, or the yel/red?
Does it matter?
Really don't want to fry anything.
Does it matter?
'81 Kawasaki kz550 ltd
'71 Yamaha xs650
'71 Yamaha xs650
Re: '81 kz550 ltd, ignition coil wiring help
03 Feb 2014 01:41Calebjkd wrote: Right in the middle of wiring up my 1981 kz550 ltd and I'm not sure what to do.
Does it matter?
It should not matter, because the coil primary terminals are non-polar.
But in cases where the coil terminals are marked positive and negative, would attach the red/yellow (switched battery positive) to the coil terminal marked positive.
The following user(s) said Thank You: Calebjkd
- Calebjkd
03 Feb 2014 02:55
Thanks patton!!
That's what I had assumed but wanted a second opinion.
Really appreciate it!!
'71 Yamaha xs650
'71 Yamaha xs650
