tach and speedo problem
- jonarmstrong
02 Feb 2014 16:44
Hey all, my Speedo and tach are jumping around. Speedo is bouncing between 35-45 when I'm running 60. Tach is bouncing around the same way. I cheched for loose connections or grounds but didn't find any. Any help is appreciated
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
- murquiza
Re: tach and speedo problem
02 Feb 2014 17:02
Did you grease your cables?
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
- jonarmstrong
02 Feb 2014 17:16
It's electric. 82 kz1000
- floivanus
02 Feb 2014 17:21
Check to make sure twelve volts goes to your gauges, also there is a troubleshooting section in the shop manual under the electrical section for your gauges
Past; 78 kz1000, 83 kz550
Andrew
Andrew
The following user(s) said Thank You: jonarmstrong
- 4TheKZ1000
02 Feb 2014 17:30 - 02 Feb 2014 17:31
I'm reaching on this one, so be kind.
Could it be non-resistor or resistor plugs causing interference with electrical equ?
Last edit: 02 Feb 2014 17:31 by 4TheKZ1000.
- jonarmstrong
02 Feb 2014 17:56
I guess its possible but this just started and I havnt changed the plugs
