resistor for coils ?
  • rlcarter
  • rlcarter's Avatar Topic Author
01 Feb 2014 11:44
#620812
hello . members .. 1980 kz1000G mounted to the frame under the tank is a porcelin connector i think is a resistor i broke part of the porcelin off . the wires are still connected .will it still work or should i replace it
1980 KZ1000 G w/carbs..
Re: resistor for coils ?
01 Feb 2014 13:36 - 01 Feb 2014 13:36
#620819
No eBay APP ID and/or Cert ID defined in Kunena configurationI would replace it. If it's the part labeled #9 in the Kawasaki.com diagram there's one available on eBay. Ed
Attachment 00007_2014-02-01.jpg not found
Last edit: 01 Feb 2014 13:36 by 650ed.
  • bountyhunter
  • bountyhunter's Avatar
01 Feb 2014 22:42
#620884
Weird, I didn't know any of the kawis used a ballast resistor?
  • rlcarter
02 Feb 2014 05:09
#620897
yeah its the one labeled # 9 thanks for your help. ill check out ebay
  • rlcarter
02 Feb 2014 07:08
#620901
does anyone know if there is a newer or different resistor i could use to replace the original one on my 1980 kz 1000G
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
02 Feb 2014 08:54
#620905
That is too much money. For a little more money you could buy some Dyna coils and replace those old coils and not need the resistor.
  • Motor Head
  • Motor Head's Avatar
02 Feb 2014 10:18
#620908
If you broke the outer white porcelain, but not the internal wire coil. Use an OHM meter to measure the resistance. It also may be stamped on the outer shell. Once you know the OHM Value, you can find a replacement for well under $20. NAPA, O'Reilly's, etc. Or back to FEE Bay. Even a CAR Wrecking Yard with some older points model cars if your desperate for cash.
  • loudhvx
  • loudhvx's Avatar
02 Feb 2014 10:19 - 02 Feb 2014 10:21
#620909
That's crazy. Any generic 1 ohm ballast should work, and should only be a few dollars. As Roy said, if you eventually get new coils, you will eliminate the ballast completely.
EDIT, Dang, Motorhead beat me to it. :laugh:
Last edit: 02 Feb 2014 10:21 by loudhvx.
  • rlcarter
03 Feb 2014 02:50
#620959
i love this forum. you guys are great.thanks for the input very helpful
  • Lazyman06
  • Lazyman06's Avatar
03 Feb 2014 11:43
#620987
Good to know that you don't need that resistor if you have dyna coils cause I lost mine a long time ago lol
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
