Dyna s problem
- holmes
Dyna s problem
30 Jan 2014 20:41
i started having a problem a couple moths ago where i would ride and cylinders 2 and 3 would cut out at random. i thought i solved the problem when i fixed some connections. however, i went to start my bike up today and cylinders 2 and 3 wont fire. i have a dyna s ignition system and accel coils (installed by PO), and the bike ran beautifully a week ago. i believe i have the problem traced back to the dyna s. i had no spark to cylinders 2/3, but when i switched the power wires going to the coils i got spark in 2/3 but not 1/4. the left dyna s module is supposed to fire 1/4 correct? when i have the left hand module going to those cylinders, nothing, but when i have the right hand module going to the coil that powers 1/4 those 2 cylinders fire, but not 2/3. could one of the modules be faulty? i have a 79 kz650 c3 by the way.
1979 kz650 c3
- kaw-a-holic
Re: Dyna s problem
30 Jan 2014 21:04
Have you went to their Website and downloaded the trouble shooting yet? Complete that first then call Dyna. The hold time is long but they have a great bunch of guys.
www.dynaonline.com/skins/downloads/
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- 4TheKZ1000
Re: Dyna s problem
31 Jan 2014 04:41
That's a pretty damming indictment on the Dyna-S module plate.
I think you have it well in hand and mostly solved, but spend the extra time running it all down again, listen to the forum advice.
Don't get tunnel vision and miss something.
- z1kzonly
Re: Dyna s problem
31 Jan 2014 05:41Speaking of Dyna S, before I call them or wait for an email reply.kaw-a-holic wrote: Have you went to their Website and downloaded the trouble shooting yet? Complete that first then call Dyna. The hold time is long but they have a great bunch of guys.
I have heard of guys sending them the units to test and diagnos.
Anyone know what they charge?? I have 3 Dyna S units that have been sitting for many years.
This was an old pic. when I was selling bikes last year.
Priority back & forth only $11, I can send them a prepaid return mailing package.
- turboking
Re: Dyna s problem
31 Jan 2014 07:27
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- KZB2 650
Re: Dyna s problem
31 Jan 2014 08:26z1kzonly wrote:Speaking of Dyna S, before I call them or wait for an email reply.kaw-a-holic wrote: Have you went to their Website and downloaded the trouble shooting yet? Complete that first then call Dyna. The hold time is long but they have a great bunch of guys.
Check with em but I remember they told me around 80 dollars plus postage when one of my module burnt out and that was in maybe 03 or 04. I threw my points back in and went with a new one after the rebuild.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- kaw-a-holic
Re: Dyna s problem
31 Jan 2014 08:41KZB2 650 wrote:z1kzonly wrote:Speaking of Dyna S, before I call them or wait for an email reply.kaw-a-holic wrote: Have you went to their Website and downloaded the trouble shooting yet? Complete that first then call Dyna. The hold time is long but they have a great bunch of guys.
Mine was still under warranty so it only cost me shipping to them. The trouble shooting determined what was wrong, bad module. They had to test it to replace it for free. There tech support is over the phone is free. Email support takes forever and would not suggest it. Had my replacement parts by the time they emailed me back for support.
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
- baldy110
Re: Dyna s problem
31 Jan 2014 08:51
Did you happen to crank the engine over while the sparkplugs were out? That will fry a module really quick.
Re: Dyna s problem
31 Jan 2014 11:42holmes wrote: . . . no spark to cylinders 2/3, but when i switched the power wires going to the coils i got spark in 2/3 but not 1/4 . . . .
power wires
A coil's primary winding is powered by the battery.
The coil charges while its primary winding is grounded through a Dyna-S module.
The coil fires when the Dyna-S module "ungrounds" the coil's primary winding.
With wires connected normally, and ignition switched ON, is full battery voltage being received at both ignition coils?
- sbc1320
Re: Dyna s problem
31 Jan 2014 12:19baldy110 wrote: Did you happen to crank the engine over while the sparkplugs were out? That will fry a module really quick.
I believe Dyna says to pull the plugs and spin the motor over to check for spark.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- nitsua93
- I brake things.
Re: Dyna s problem
01 Feb 2014 15:11
I just started having this problem yesterday. I should have looked before starting the thread I just started which basically states your exact same problem. Let us know if the new plate fixes things!
I can't leave this blank.
- baldy110
Re: Dyna s problem
01 Feb 2014 15:54sbc1320 wrote:baldy110 wrote: Did you happen to crank the engine over while the sparkplugs were out? That will fry a module really quick.
Dyna does say that but if you pull all the plugs and test one cylinder at a time for spark without plugs in the remaining leads, grounded out you will blow a module.
