Switching sparkplug wires
  • Schmeck
  • Schmeck's Avatar Topic Author
27 Jan 2014 15:56
#620268
I feel like this is a dumb question but you never know. Is there a specific side for where each spark plug wire goes to? Like one wire has to go left and the other has to go to the right on a kz750 twin. My bike backfired through the carburetor and Im wondering if Switching the plugs sides would throw off timing ect.
Thanks,
Schmeck
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
  • TexasKZ
  • TexasKZ's Avatar
Re: Switching sparkplug wires
27 Jan 2014 16:18
#620274
Makes no diff. Both plugs fire at the same time, one on compression, the other on exhaust, the visa versa.
The following user(s) said Thank You: Schmeck
  • Schmeck
27 Jan 2014 16:25
#620275
Okay I wanted to make sure . Thanks for replying
  • MFolks
  • MFolks's Avatar
27 Jan 2014 18:40
#620292
Check your sparkplug caps, if they're what came with the bike, think about getting new ones. The 5000 ohm internal resistor can fail/become intermittent, due to heat, vibration, and age. Z1 enterprises sells new ones.
  • steell
  • steell's Avatar
27 Jan 2014 19:15
#620300
If you remove the timing advancer cam/rotor, it is easy to install it 180 off and it will backfire through the carbs when you try to start it. Most 750 twin owners here have done that at least once (including me).
  • Schmeck
28 Jan 2014 10:53
#620347
Yeah I am not sure what is causing it . I think it's my plug caps but will check timing advancer. I'm have a 2 into 1 intake but it ran fine so I don't think it's that . Am going to redo my wiring anyways and will replace plug caps and check advancer . thanks
  • Schmeck
28 Jan 2014 11:21
#620350
Okay so if the timing advancer lobe was backwards the gap would close when the plate is turned to the right correct? I am all of a sudden confused.
28 Jan 2014 11:42
#620351
Schmeck wrote: Okay so if the timing advancer lobe was backwards the gap would close when the plate is turned to the right correct? I am all of a sudden confused.
Take a close look at the outer edge of the little cam on your timing advancer. If it is marked similar to that of my KZ650 you will see a short line stamped into it (see my advancer in photo below for details). If that is there, take a look at the backplate portion of the advancer. Again, if it is similar to my KZ650, you will see a small round hole in it. The little cam should be installed on the shaft so the little line on the cam is near the little hole in the backplate. If the line is 180 degrees away from the little hole, the little cam is on the shaft 180 degrees out and needs to be pulled off, turned 180 degrees, and re-installed. It can only be installed one of those 2 ways - it's either correct or 180 degrees off. Ed
Attachment AdvancerCloseupwCircles.jpg not found
  • Schmeck
28 Jan 2014 12:07
#620355
Thanks for the picture and ect it really helps out.
  • Schmeck
29 Jan 2014 07:50
#620457
I checked my advancer and it is on correctly. Reset the timing for .014" and all that. I even set my engine on F and turned it alittle while looking into the intake holes. No bent or leaking valves. I had the valves serviced a few months ago so I know its not them. Im going to say its either my bikes wiring or sparkplug caps. If this is true the bike will run good when I make the new wiring harness and put new plug caps on.
