Turn signal relay for KZ 1000
- anotherZ
26 Jan 2014 18:04
No eBay APP ID and/or Cert ID defined in Kunena configurationI bought an aftermarket part on ebay and it was shot after using the turn signal 5 times. I had gotten this one and I guess you can't do much wrong hooking it up. Could it be the incorrect wattage? Thanks!
79 KZ 1000 LTD
Saved it from becoming a drag bike
Smaller tank
Smaller tank
Re: Turn signal relay for KZ 1000
26 Jan 2014 18:30
I installed a Tridon/Stant 552 2 prong electronic flasher about 9 years ago. No problems, and it make the flashers always flash at a consistent rate regardless of the condition of the battery because it's electronic rather than relying on resistance. So if your new one doesn't work or fails you may want to give one a try. Any automotive parts store sell them and (like me) they are cheap. :laugh: Ed
The following user(s) said Thank You: anotherZ
- anotherZ
26 Jan 2014 19:17
Great advice, thanks. I like parts that cost less than a Whataburger! Will give it a try!
79 KZ 1000 LTD
Smaller tank
Smaller tank
- z1kzonly
26 Jan 2014 19:28
It's a little too late. But I had this Good Old USA Wagner, that just sold. With a OEM Z1 rubber for 10.00
An ebay item that sold.
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&r...0271180#ht_425wt_900
Every one should check ebay first, to just look! And see what's available.
Attachment 000_0012.jpg not found
- anotherZ
30 Jan 2014 13:28
650ed, followed your advice and bought the part from Autozone. Works great! And as you say, flashers always flash at a consistent rate which is great! Thx again!
79 KZ 1000 LTD
Smaller tank
Smaller tank
30 Jan 2014 13:33
Glad I could help!
