Lithium ion batteries
- bountyhunter
Re: Lithium ion batteries
26 Jan 2014 18:07 - 26 Jan 2014 18:10
OK, maybe it is possible. The data from this charging IC for Li Fe PO4 batteries shows the fully charged cell voltage should be about 3.6V/cellso a "12V" battery would have four cells and be fully charged at approximately 14.4V which is closer to being compatible with a MC charging system......
www.ti.com/lit/an/slua565/slua565.pdf
Last edit: 26 Jan 2014 18:10 by bountyhunter.
- les holt
26 Jan 2014 18:15
I've been looking for a recommendation from I believe it was ricks motorsports electrics, it said that the 1 pc. reg/rect replacement for the old style 2 piece setup isn't recommended or couldn't guarantee them for use with the lithium batteries due to voltage not being stable enough to maintain the proper charging parameters for them. Don't hold me to it being Ricks but I do recall reading that. Just can't find it again.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- Hollywoodmx
26 Jan 2014 19:00les holt wrote: I've been looking for a recommendation from I believe it was ricks motorsports electrics, it said that the 1 pc. reg/rect replacement for the old style 2 piece setup isn't recommended or couldn't guarantee them for use with the lithium batteries due to voltage not being stable enough to maintain the proper charging parameters for them. Don't hold me to it being Ricks but I do recall reading that. Just can't find it again.
Les
I have two antigravity batteries. Swapping your vintage rectifier for a mosfet one is is supposed to ideal for these batteries.
You can get mosfet regulators a couple ways. Off wire harness online stores or from junkyards/eBay. Expect to pay 50 on average. You will either need to make your own wiring as they have specific connectors or buy connectors from these wire harness shops.
To know which regulators are mosfet, search Google and there should be a thread in a Honda forum IIRC.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- anotherZ
26 Jan 2014 19:14
I used combined reg/recs from here
www.oregonmotorcycleparts.com/rectifiers3p.html
with the antigravity battery for my CB 750. I believe the KZ charging system works the same:
Never had any issues again!
79 KZ 1000 LTD
Saved it from becoming a drag bike
Smaller tank
Smaller tank
- les holt
26 Jan 2014 19:49
Thanks
I'll try the mosfet ones, it's been a long time since I've looked at this stuff.
Les
Thanks
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- kaw-a-holic
26 Jan 2014 21:01
All great information thank you guys. I will have to look into the newer reg/rectifier combo.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- z1kzonly
26 Jan 2014 21:47
Or around 600 or 700 cells can pilot you down the 1/4 at 200 MPH's
www.motorcycle-usa.com/4/8134/Motorcycle...Sets-1-4-Record.aspx
- saxjonz
- KawboyZ
26 Jan 2014 22:56
I've had mine in for two years going on 3. Starts strong and has not failed yet. I love it but bang for the buck it is not. I bought a battery for my kz that lasted five years, the fiberglass mat gel cells are really nice. I would never again run a battery that required a vent hose. Never.
I had a Yuasa battery that only lasted 3 years and I paid three times (almost) the amount I bought this gel cell for. I think I even bought it off of ebay. five years. My 03 rex battery I put in my 02, still going strong after 11 years. HEY. I heard that the factory stock batteries last much longer than replacements? I dunno. I do know that I always take them out in the winter and trickle charge them till they are full then take them off and leave them alone. When I did leave my battery on a trickle charger it died so... The weight advantage on a heavy kaw is not going to even be felt. Sure, you might notice a 1 pony increase but I doubt it. So, get a gel cell or shorai but I know a gel will last a long time and I know that the lithium batteries have issues, even heard that they like to explode like some cell batteries do after years of use. I dunno. I do know my experience has been all positive with both gel and lithium.
79 LTD B3
- 0Z.Z1R Mk2
27 Jan 2014 02:54
I've been using this "believe it or not" a LiPo hobby battery in my Kat for 8 months.
It has superior cranking power and has never let me down as yet.
A balance charger is recommended...but I haven't had to use it as yet.
www.hobbyking.com/hobbyking/store/__1622...000mAh_4S1P_30C.html
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
- saxjonz
- KawboyZ
27 Jan 2014 09:29
Wow, now that is thinking outside of the box.
Creative!
Creative!
79 LTD B3
- Jrbrownie00
07 Apr 2014 18:27 - 07 Apr 2014 18:28
so a new RR from ricks or oregon would work nicely?
82' kz750 ltd.
Last edit: 07 Apr 2014 18:28 by Jrbrownie00.
- kaw-a-holic
07 Apr 2014 19:16Yes, and he stands behind his equipment. He states that if you wire it wrong and it fries he will replace it at cost. That's pretty awesome.Jrbrownie00 wrote: so a new RR from ricks or oregon would work nicely?
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
