Dyna coils or stock replacement?
- HAFROD
18 Jan 2014 20:49
At Z1 the stock replacement coil set is $105. The Dyna coils are around $150. I have the Dynas in my 78 KZ1000. Is it worth paying the extra money for the Dyna coils? The stock replacements come with wires and boots?
Two 1983 GPz 305's, 1984 GPz550, 1980 KZ550A, 1978 KZ1000A2A
- koolaid_kid
Re: Dyna coils or stock replacement?
18 Jan 2014 23:13
The Dynas will deliver a hotter spark. If you have to replace, upgrade. I prefer to use the Dyna suppression wires and forgo the individual expensive suppression caps.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- dkoz
19 Jan 2014 06:16Hi half rod..I've been over this with a few people here and it seems to me if your running say a dyna s ignition . Its best to go with the green dyna coils..I had stock style coils that ohmed at 4.5 and ran with the dyna s. But I got better performance with the coils that matched the ignition.. so stock coils with 4.5 ohm. Should go with points and condenser's....HAFROD wrote: At Z1 the stock replacement coil set is $105. The Dyna coils are around $150. I have the Dynas in my 78 KZ1000. Is it worth paying the extra money for the Dyna coils? The stock replacements come with wires and boots?
Dyna should match what ever ignition you want to run.
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
- HAFROD
19 Jan 2014 08:26
So the Dyna coils is just like putting an MSD ignition system on your race car. Usually a hotter ignition will let you go up in jetting a bit. Is this sound about right? Sounds like a good upgrade for not much more money. Since I have not heard my KZ run and most of it came in a big tote, I'm just going to buy a set of coils to delete any future headaches. My coils look like the originals. I probably should check the Dyna s to make sure its OK. Hopefully they have something on their website about checking it out. I did not get any paperwork with it.
