ZC006-TR12V for KZ650?
  • murquiza
  • murquiza's Avatar Topic Author
01 Jan 2014 08:44
#616942
Will the coils ZC006-TR12VS work on a KZ650-D2? The bike has a set of ZC002-12V, my understanding is that the ZC006 are for electronic ignition like the H1, but I was wondering if anybody has tried them in an earlier KZ650 with success.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
Re: ZC006-TR12V for KZ650?
01 Jan 2014 10:00 - 01 Jan 2014 10:01
#616955
murquiza wrote: Will the coils ZC006-TR12VS work on a KZ650-D2? The bike has a set of ZC002-12V, my understanding is that the ZC006 are for electronic ignition like the H1, but I was wondering if anybody has tried them in an earlier KZ650 with success.
Depends on what ignition is fitted and whether the resistance of the coils is compatible with the ignition.
With stock points ignition, each stock coil was likely a 3~4 ohm resistance.
If the ignition has been replaced with an electronic ignition, such as Dyna-S, then 3 ohm coils (such as Dyna green coils) are recommended.
It's possible also that the stock ignition might have been replaced by some other electronic ignition, such as the igniter style ignition from a later model (uses lesser ohm coils) .
Would use an ohmmeter to measure the primary resistance on the new coils at hand to determine the resistance of each coil.
Then decide whether the resistance is compatible with whatever ignition system is now already fitted.
Good Fortune! :)
Last edit: 01 Jan 2014 10:01 by Patton.
  • MFolks
  • MFolks's Avatar
01 Jan 2014 10:16
#616959
If you are not familiar with the use of a multimeter, watch this video:
The best multimeter tutorial
  • MFolks
  • MFolks's Avatar
01 Jan 2014 10:18
#616961
Sorry,it looks like it's blocked, preventing a download.
  • loudhvx
  • loudhvx's Avatar
01 Jan 2014 12:01
#616970
That video plays for me just fine.
  • MFolks
  • MFolks's Avatar
01 Jan 2014 12:35
#616976
I think I've solved the problem, the active X setting was preventing the original download.
  • murquiza
01 Jan 2014 14:23
#616985
MFolks wrote: If you are not familiar with the use of a multimeter, watch this video:
I am, thank you ;)
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
