Where do I find a wiring diagram for 1980 KZ550?
- HAFROD
21 Dec 2013 20:59 - 21 Dec 2013 21:10
Preferably the black and white labeled version. I found a color one but the colors are not correct. I'm not getting power to my start button or my RUN button (yellow wires). I'm also not getting anything on my blue wire that runs to fuse box. I pulled apart the connector and plugged it back in. All the connections look pretty bad. I was going to try and start it.
Two 1983 GPz 305's, 1984 GPz550, 1980 KZ550A, 1978 KZ1000A2A
Last edit: 21 Dec 2013 21:10 by HAFROD.
- HAFROD
Re: Where do I find a wiring diagram for 1980 KZ550?
21 Dec 2013 21:27
I found a 7 year old post on a bare bones wiring harness for starting and charging but the links are dead. It probably would be better for me to hot wire it since all the wiring is in very bad shape. I want to see if the motor runs good before I do anything with the bike.
- ed spangler
- Tennessee Z
22 Dec 2013 03:08HAFROD wrote: Preferably the black and white labeled version. I found a color one but the colors are not correct. I'm not getting power to my start button or my RUN button (yellow wires). I'm also not getting anything on my blue wire that runs to fuse box. I pulled apart the connector and plugged it back in. All the connections look pretty bad. I was going to try and start it.
Contact MFolks on this site, hes a wiring/electrical GENIUS!!
Regards
TennesseeZ Ed
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
- lightitup
22 Dec 2013 04:52
loudhvx has some great info and has made a website for it as well
home.comcast.net/~loudgpz/GPZweb/index.html#home
81 kz 550 ltd
