Coils and their wiring connections 78 KZ
- HAFROD
19 Dec 2013 08:24
I've got two wires on each of my coils. both have yellow with red stripe. The right coil has a green and the left has a black. From the diagram posted I can see the yellow/red stripe is power but whats the black and green? Can I chassis ground them for a HOT wire engine test?
Two 1983 GPz 305's, 1984 GPz550, 1980 KZ550A, 1978 KZ1000A2A
- Cynjut
Re: Coils and their wiring connections 78 KZ
19 Dec 2013 08:26
Those wires connect to the red and black (IIRC) on your Dyna-S. If you don't have a Dyna-S, they connect to the points in the point cover.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- StreetfighterKz
19 Dec 2013 08:29
The black and green go the the Dyna S you have installed. They do ultimately ground the coils causing the coils to fire but you have to hook them up to the ignition plate for them to work correctly.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
