Dyna s on 78 KZ1000 3 wire hook up??
- HAFROD
18 Dec 2013 20:38
I have 3 tiny wires coming from the Dyna s. A red, black, and white. What do these go to? I bought this basket case a couple days ago and there's a brand new wiring harness from Kawasaki. There's wires everywhere
Two 1983 GPz 305's, 1984 GPz550, 1980 KZ550A, 1978 KZ1000A2A
- 4TheKZ1000
Re: Dyna s on 78 KZ1000 3 wire hook up??
19 Dec 2013 03:44 - 19 Dec 2013 03:46
Ok, you have 2 coils. One sparks 1 and 4 plugs the other sparks 2 and 3 plugs. the dyna s has two wires that go to coils.
red is power.
the white and black go to coils
Know that the black button or the magnetic pickup has a slot cut in bottom.
the button has one magnetic pickup so it can be installed 180 out or incorrect.
this happened to me and bike backfired and wouldn't run.
if this happens take black button and turn 180 and reinstall.
red is power.
Last edit: 19 Dec 2013 03:46 by 4TheKZ1000.
- ZERO
19 Dec 2013 05:38
Google Dyna. Email them. They'll send a schematic for any of thirty systems. Been there....
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
- HAFROD
19 Dec 2013 22:50
I just read on another thread about removing the IC Ignitor if you run a Dyna s. Does my 78 have an IC Ignitor? If it does, where is it? Sorry for all the questions guys but I got a basket case here and its my first older bike.
20 Dec 2013 10:12 - 20 Dec 2013 10:15'78 had points, and no igniter.HAFROD wrote: I just read on another thread about removing the IC Ignitor if you run a Dyna s. Does my 78 have an IC Ignitor? If it does, where is it? Sorry for all the questions guys but I got a basket case here and its my first older bike.
Dyna-S is powered by red wire from switched battery positive (spliced into harness wire such as the red or red/yellow wire before the dual connector feeding the two coil wires, OR plugged into an unused accessory plug that provides switched battery positive)
Under the points cover, the wire from the left-hand 9 o'clock rear located Dyna-S module attaches to the ignition coil that fires the two outside spark plugs #1 and #4.
Under the points cover, the wire from the right-hand 3 o'clock forward located Dyna-S module attaches to the ignition coil that fires the two inside spark plugs #2 and #3.
Last edit: 20 Dec 2013 10:15 by Patton.
- kaw-a-holic
07 Jan 2014 03:53
Dyna provides downloadable instructions on their website. They also have great guys you can call for tech support just plan on a 20 minute hold time.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- Old Man Rock
07 Jan 2014 04:15 - 07 Jan 2014 04:18
Here...
Dyna S Installation......
NOTE: Best to Solder the 12Vdc power versus their supplied splice....
Attachment DynaSIgnitionPlateInstall.jpg not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 07 Jan 2014 04:18 by Old Man Rock.
- mrdatsunturbo
- mrturbo Norway
16 Mar 2014 23:15
I am doing the rest of electrical on my holland bike before start up ,it came with new Dyna and at the
pick up plate the two lower wire on mine is red?
Is this a problem or will it be the same 1-4 and 2-3 as this topic?
- mrdatsunturbo
- mrturbo Norway
17 Mar 2014 00:34
exactly what i was looking for,Thanks again
17 Mar 2014 00:47 - 17 Mar 2014 01:44Attachment Dyna-Swirecollarcolor.jpg not found
Regardless of coil mounting positions, left Dyna-S module wire always goes to whichever coil fires outside plugs 1/4, and right Dyna-S module wire always goes to whichever coil fires inside plugs 2/3.
Last edit: 17 Mar 2014 01:44 by Patton.
17 Mar 2014 01:05 - 17 Mar 2014 01:06mrdatsunturbo wrote: I am doing the rest of electrical on my holland bike before start up ,it came with new Dyna and at the
mrdatsunturbo wrote: exactly what i was looking for,Thanks again
The above diagram is correct for Z1 and KZ900-1000.
KZ650 and some others have left coil to inside plugs 2/3 and right coil to outside plugs 1/4.
Last edit: 17 Mar 2014 01:06 by Patton.
The following user(s) said Thank You: cartal
