Q: battery warning light and neutral
- yeekim
15 Dec 2013 08:26 - 15 Dec 2013 08:26
Hoi!
'88 KZ 750 P1
How to eliminate the battery warning light from flashing in dash?
Have no sensor.
Second:
In neutral the high beam light is on and if on high beam there is no indication at all- is there a wire mix-up or just :blink:
greetings
'88 KZ 750 P1
Have no sensor.
Second:
greetings
Ex nihilo nihil fit!
Last edit: 15 Dec 2013 08:26 by yeekim.
- ZERO
Re: Q: battery warning light and neutral
16 Dec 2013 02:23 - 16 Dec 2013 02:25
I had that on my GPZ1100. I took out the battery bulb. (You need a sensor type battery.) When you're in neutral, is your neutral light on also or just high beam? Maybe someones been inside there and the bulbs are in the wrong socket holes.
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
Last edit: 16 Dec 2013 02:25 by ZERO. Reason: unclear
- yeekim
16 Dec 2013 07:56 - 16 Dec 2013 08:25
Removing the bulb is not the solution- red general warning light is blinking to
And battery warning is LCD
Last edit: 16 Dec 2013 08:25 by yeekim.
- ZERO
16 Dec 2013 08:35
Oh, L.C.D. Sorry. Do you have a schematic? Is it a floating ground switch? There's got to be a way around it.
- StreetfighterKz
16 Dec 2013 08:43
My '83 Gpz750 doesn't have a sensor but should. Someone, previous to me, just stripped the wire back and put the sensor lead to the + on the battery.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- OnkelB
16 Dec 2013 11:24 - 16 Dec 2013 11:25StreetfighterKz wrote: Someone, previous to me, just stripped the wire back and put the sensor lead to the + on the battery.
That's what I did on my GPz 1100 (before installing an Acewell gauge.) Find the battery sensor wire (don't know your bike but on the 1100 it's pink) and connect it to battery plus and the warning light should turn off.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 16 Dec 2013 11:25 by OnkelB.
