tailight wiring
- Schmeck
tailight wiring
12 Dec 2013 12:20
So Im running a harley tombstone tailight and the problem I have run into is that it only has 2 wires . A red and a black . I wanted to have the tail as a running light and also a stop lamp like the previous taillight . Is there a way to do this ? I combined the two wires into the one red and its just the same brightness all the time. Can someone school me on this ?
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
- bountyhunter
Re: tailight wiring
12 Dec 2013 12:33
You would need to replace the single filament socket with a dual filament one so it has two hot wires, one for low and high brightness filaments.
- Schmeck
Re: tailight wiring
12 Dec 2013 12:37
If you are refering to the bulb having a tall wire and a shorter wire infront of it then it has that .
- dkoz
Re: tailight wiring
12 Dec 2013 12:37
you need a double filament bulb as well
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
- Schmeck
Re: tailight wiring
12 Dec 2013 12:38
Or are you saying put in two bulbs ?
- dkoz
Re: tailight wiring
12 Dec 2013 12:40
Hes referring to the socket that the bulb fits into
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
- Schmeck
Re: tailight wiring
12 Dec 2013 12:45
it is a dual I think . heres a pic
Attachment image_2013-12-12.jpg not found
- Schmeck
Re: tailight wiring
12 Dec 2013 13:03
if i tied two wires ( runnning and stop) together into the one positive wire for the harley light , should this work ? because I tried it and it didnt lol
- Schmeck
Re: tailight wiring
12 Dec 2013 13:55
Nevermind I figured it out lol . both 2 wires are hot and the tailight housing itself grounds to the metal fender . there is no ground wire . Interesting design.
