1996 Ninja 1000R
  • 771000LTD
  • 771000LTD's Avatar Topic Author
1996 Ninja 1000R
23 Nov 2013 15:32
#613923
Hey guys,
something keeps draining the batt after a day or so of sitting.
Any thoughts out there
thanks, stephen
  • MFolks
  • MFolks's Avatar
Re: 1996 Ninja 1000R
23 Nov 2013 15:42
#613926
Put a 12 volt light between the Negative(-) battery post/terminal and ground. If the light comes on, you've got an electrical drain. To troubleshoot where it's at, start disconnecting/pulling the fuses until the light goes out.
Do this with a fully charged battery, and the engine off.
The following user(s) said Thank You: 771000LTD
