1983 KZ650 Wiring/Battery box
  • Vranasaurus
  • Vranasaurus's Avatar Topic Author
16 Nov 2013 15:19
#613194
Can someone post some pictures showing how all the wiring is routed and the different pieces that hook onto the battery box go.
I took this thing apart and I can't figure out how all the metal pieces that hold the connectors and hook onto the battery box go.
Thanks,
Nick
1984 ZN1100
1975 Z1B
  • martin_csr
  • martin_csr's Avatar
Re: 1983 KZ650 Wiring/Battery box
16 Nov 2013 18:26 - 17 Nov 2013 13:10
#613206
Try the diagrams at Kawasaki.com or Partzilla. The parts should be oriented correctly in the drawings - you just need to un-explode them. The battery case diagram is the primary reference. The air cleaner diagram shows a couple of L brackets that should attach to the battery case. The igniter attaches to the back side of the "electro base bracket" (#11034) - probably bolt the igniter to the bracket 1st, then install the bracket.
KZ650.Info - Pics of behind side covers and electro base cover
Last edit: 17 Nov 2013 13:10 by martin_csr.
  • martin_csr
16 Nov 2013 18:41 - 17 Nov 2013 13:12
#613207
In the 1st electro photo in the linked topic at the upper left, there's a bolt & large washer - that's one of the frame connection points for the "electro base bracket" - the bolt has a bushing & damper. The other frame connection point for that bracket is diagonally to the lower right. Directly below the bright silver bolt is a threaded hole - that's one of the attachment points for the plastic electro cover - the Kaw diagram illustrates the other attachment point.
#11036 is for the acc fuse box.
#11036A should be obvious - it's connected to the battery case & #11036B which probably bolts to the underside of the battery case, along w the voltage regulator (the fuel check switch or outage indicator switch may be attached to it).
Last edit: 17 Nov 2013 13:12 by martin_csr.
  • Vranasaurus
17 Nov 2013 10:34
#613275
I think I got it. Thanks Martin.
1984 ZN1100
1975 Z1B
