Charging question on 305 CSR
  • Cynjut
  • Cynjut's Avatar
Re: Charging question on 305 CSR
08 Nov 2013 12:33
#612502
loudhvx wrote: Unplug the connectors from the reg/rec, and unplug the headlight.You should be able to ride over 100 miles on a fresh battery that way.
I should have thought of that. You are right on.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • happyhunter
  • happyhunter's Avatar Topic Author
10 Nov 2013 19:56
#612741
I bought a new battery on Saturday and tried it in the bike today. I fired up and I measured a charging system voltage of 14.5 VDC. So the regulator was fine. Just needed a battery.
Now after having 22 volts or so on it last week it did blow a couple light bulbs out. The seller had a rear/brake bulb on hand. I am going to pick up a new headlight this week. Next Sat I should pick up my first motorcycle. I'm kinda excited. :cheer: :cheer: :cheer:
Thanks for the help,
HH
'82 Kawasaki KZ305CSR
I did not set out to buy a project bike,
but I got one anyway.
